Author Topic: Wonder goes to Rausch  (Read 49773 times)
Re: Wonder goes to Rausch
« Reply #15 on: February 09, 2012, 07:43:09 PM »
How far is that? and how'd the tahrs like it?
« Reply #16 on: February 09, 2012, 07:50:22 PM »
didnt look didnt care.  im sure you can see the marks from the pizza corner light to where its parked at the shop.
really scary that for like only the last 10 miles i herd a little whine in the rear end and then all the sudden coming home from sears down the W hen hill the rear end was pissed under coast load.  almost made it to the shop but it went bang when i had to slow down for a light.  blew the slip yoke apart and pinion locked up.  i dragged it off to the side of the road before even getting out to see the rear shaft hanging.  pulled it, and drove it home in 4low with the rear locked squealing, dragging, and doing its locked up thing.
« Reply #17 on: February 09, 2012, 07:52:08 PM »
just my luck after i said i wouldnt put a dime into stock axles, and i just did all the brakes/cylindars in the rear.  FML
needs tons and a set of KRTs
« Reply #18 on: February 09, 2012, 07:55:59 PM »
What a machine!
« Reply #19 on: February 09, 2012, 08:13:01 PM »
screw it  this hog is getting 8 lugs
« Reply #20 on: February 09, 2012, 08:14:48 PM »
isn't there a D35 out back?  Even set up for leafs?
« Reply #21 on: February 09, 2012, 08:17:53 PM »
ill pull it apart and check it out but after snaping ujoints and now blowing the rear end i am just not cut out for stock shit on jeeps
« Reply #22 on: February 09, 2012, 08:24:11 PM »
you need a DD 4cyl fuel sipper MJ while you build this
« Reply #23 on: February 09, 2012, 08:42:05 PM »
na, the wonder his heritage now.
think its done with stock axles and 35's though....
the shovel might get the scrapper earlier than planned.
« Reply #24 on: February 09, 2012, 08:52:58 PM »
I have a sweet set of H2 wheels here you can use.  ;D
« Reply #25 on: February 09, 2012, 09:00:50 PM »
Yeah right you are way too attached to the shovel
« Reply #26 on: February 09, 2012, 09:03:04 PM »
it is a sweet hog, but there is like no snow out and my plazma is hungry.
« Reply #27 on: February 10, 2012, 08:46:26 AM »
I bet you could sell those mirrors to mikemike so he can be like Roy :)
« Reply #28 on: February 12, 2012, 06:56:33 PM »
that was a lot of work.
rear axle back in service.
Tcase is messed up and shifting like when i got it.  its slipping into 4x4, and a pile to try to get it into low and the back to 2.  tried adjusting it, no go.   might have bent something when it locked up or when i yanked on it.
was working 100% before lockup.
« Reply #29 on: February 13, 2012, 09:57:30 AM »
if you are looking to replace the t-case.. I will have an extra 231 and slip yoke shaft after I swap in the rubi-case... if that happened to happen sooner rather than later it could be yours.. hint. hint.
