Author Topic: matts buggy build  (Read 225168 times)
Re: matts buggy build
« Reply #300 on: October 27, 2013, 05:40:38 PM »
Nice!
« Reply #301 on: October 28, 2013, 10:22:09 AM »
Sent from my iPhone using Tapatalk - now Free
« Reply #302 on: October 29, 2013, 03:00:49 PM »
straights 3/8 24 - straight - 3/8 24    straight H8553    need (2)
Tees  End 1 Type/Size of Fitting:   Junction - (2) 3/8-24
End 2 Fitting Material:   Treated Steel
End 2 Type/Size of Fitting:   Female - 3/8-24    3 way block H36778 need (2)
End 1 Type/Size of Fitting:   Banjo - 0.4375
End 2 Type/Size of Fitting:   Female - 3/8-24   15" long front hose H80965 need (2)    looking for longer ones still
H380534
H380533   say 10mm banjo, 24" long instock advance  left and right
« Reply #303 on: October 30, 2013, 10:53:59 AM »
sweet M4 shifter installed last night
fuel line shutoffs done
started on some wires
« Reply #304 on: October 31, 2013, 02:18:26 PM »
« Reply #305 on: October 31, 2013, 02:28:19 PM »
thats the same unit i got in the toyota!
« Reply #306 on: October 31, 2013, 02:59:07 PM »
Wow it does exist!
« Reply #307 on: October 31, 2013, 03:04:10 PM »
Wow it does exist!
« Reply #308 on: November 01, 2013, 09:45:13 AM »
fuel lines / valves ran to cell last night
fuel pump mounted
disconnect dash tube / panned run and mounted
over flow tank plumbed
tires back on, rolled off the lift.
New Frated tires and wheels mounted on enclosed trailer
« Reply #309 on: November 01, 2013, 09:49:37 AM »
fuel pump mounted
Rust removed from all pulleys and new $50 ac Delco engine belt installed.., F!
« Reply #310 on: November 01, 2013, 09:53:17 AM »
haha
Rapped by nuway counter as a walk in     :o
« Reply #311 on: November 05, 2013, 09:35:39 AM »
$100 worth of Brake lines and fittings ordered with 30% off advanced online coupon and Paypal loot from eBay jeep junk profit.
Hydro lines and fittings on the car.
« Reply #312 on: November 11, 2013, 11:43:26 AM »
Buggy is 2wd run and drive status. Engine sounds great at idle. Gauge panel done need to wire fan and gauges.
« Reply #313 on: November 11, 2013, 11:49:42 AM »
thank god no more pushing!
coils are great thanks to my engineering acqui eye calculations on the rear trailing arms
« Reply #314 on: November 11, 2013, 12:12:17 PM »
get a small ATV or mower to do the pushing/pulling duties
