Author Topic: matts buggy build  (Read 225391 times)
matts buggy build
« Reply #120 on: April 20, 2013, 07:44:06 PM »
It's below the centerlibe
Re: matts buggy build
« Reply #121 on: April 20, 2013, 08:23:01 PM »
Curious to know the reason for the bend in the LCAs.  Longer shock length?
« Reply #122 on: April 20, 2013, 09:10:58 PM »
Shock mount needs to be lower on the arm when mounting up where it is. Trophy truck tip#1
« Reply #123 on: April 21, 2013, 06:56:36 AM »
Does that keep the arm from trying to roll over?
matts buggy build
« Reply #124 on: April 21, 2013, 09:44:42 AM »
On compression yes. But when below centerline it'll tend to roll on rebound.
« Reply #125 on: April 21, 2013, 10:51:51 AM »
I would almost dissagree with that statement.... But a lot going on there....   Wonder if the damping really over comes gravity and spring force.  And I guess limit straps are a must for tire lifting slow crawling.
« Reply #126 on: April 22, 2013, 08:57:15 AM »
both ends linked and 4 bumps mounted.
some heavy tacs and this guy will be ready to sit on tires.
Run last hood line, mount some coils, and she will be a ride height roller.
« Reply #127 on: April 22, 2013, 09:01:26 AM »
she is looking very sweet.
« Reply #128 on: April 22, 2013, 10:30:06 AM »
I'm digging it. Needs some seats to make vroom vroom noises from.
matts buggy build
« Reply #129 on: April 22, 2013, 02:35:50 PM »
« Reply #130 on: April 22, 2013, 02:37:48 PM »
finally some pictures where vertigo isnt an issue
« Reply #131 on: April 22, 2013, 09:46:46 PM »
Looking Good !!
matts buggy build
« Reply #132 on: April 25, 2013, 01:21:11 AM »
Looking at master disconnect switches on summit, any recommendations? Part I shouldn't skimp on.
Found this:
http://m.summitracing.com/parts/mor-74106
matts buggy build
« Reply #133 on: April 25, 2013, 01:21:28 AM »
Thanks gif!!!
matts buggy build
« Reply #134 on: April 25, 2013, 01:28:02 AM »
What is an acceptable range of continuous amp rating and voltage compatibility?
