Author Topic: XJ  (Read 30553 times)
Re: XJ
« Reply #60 on: November 30, 2012, 09:58:16 AM »
new floor under rear seat..
Spring hangers all cleaned up..
New Winch bumper..
Winch still in box...
« Last Edit: November 30, 2012, 10:01:37 AM by rejeep »
Re: XJ
« Reply #61 on: November 30, 2012, 12:13:43 PM »
o, and just to be clear the burn mark on the passenger side trim was already there right?  i didnt even see it till i was 100% done and moved to the other side of the truck!  after a moment of panic, i realized it was done by who ever welded in the sliders because it was no where near what i was doing, but close enough to make me think twice!   i bet we could find that at the JY
if the paint doesnt stick well to M4 seam sealer, i can fix that later if we can find the right stuff with 5 minutes and a wire wheel.  Everything i did was pretty cosmetic work, and the mounts were solid where they needed to be.
Re: XJ
« Reply #62 on: December 16, 2012, 09:54:05 PM »
plated and insured for almost a week with no more than 2 miles on the clock....
DD duty tomorrow...  finally driving this thing...
Re: XJ
« Reply #63 on: December 16, 2012, 10:05:59 PM »
i got a replacement trim piece for this guy next time its at M4
Re: XJ
« Reply #64 on: December 16, 2012, 10:14:48 PM »
sweet...  if it clunks as bad as I think it might be back....
prob needs bushings all over....
Re: XJ
« Reply #65 on: December 17, 2012, 09:40:58 AM »
wow..  forgot how floaty lifted XJ's are at speed..
456 gears and 33"s are awesome...
Re: XJ
« Reply #66 on: December 17, 2012, 12:44:21 PM »
mine drives mint, just wont hold a battery
has a little vibe in the wheel at 45  (probably tires)
Callelle
Re: XJ
« Reply #67 on: December 17, 2012, 01:33:54 PM »
Mine drives fine as well aside from the fact that it drifts a bit to the right, but it's done that since I've had it.
Re: XJ
« Reply #68 on: December 17, 2012, 01:53:08 PM »
steering box might need adjustment...
its deff floaty...
it can also be the heim track bar mount....  lets see how much I drive this thing before I invest in something different..
XJ
« Reply #69 on: December 17, 2012, 01:53:38 PM »
Smike's ram pull ended up being wasted control arm bushings. At rest it measured true but under load the from axle went out of alignment. May be worth a look if you feel like chasing it.
Re: XJ
« Reply #70 on: December 17, 2012, 02:03:58 PM »
for a generally clean truck is a rusty crusty front suspention...
might be a spring time project if:
A. I actually drive the thing
B. Its not for sale by then
C. I dont get use to the problem
D. nothing more important comes up
Re: XJ
« Reply #71 on: December 17, 2012, 03:21:38 PM »
stupid question but check tire pressure?  felt like they had 8psi in them when i loaded it.
Re: XJ
« Reply #72 on: December 17, 2012, 03:53:37 PM »
not stupid at all... I havet done anything on this other than put gas in the tank and turn the key
Re: XJ
« Reply #73 on: December 17, 2012, 04:06:32 PM »
haha, ya check tire pressure- it was a trail rig- bet they are at trail pressure.
Re: XJ
« Reply #74 on: January 07, 2013, 01:42:14 PM »
put some miles on this guy .....
Renix high idle issue has popped up.... anybody deal with this ever before I start out on my own trail..
