Author Topic: XJ  (Read 34708 times)
Re: XJ
« Reply #30 on: November 12, 2012, 11:07:43 AM »
saturday, 4:26 you should have a txt from me.
anyhow, i need the 3 orings in the oil filter housing.  It was required to removed this housing to get the motor mount bolt out on the passenger side.  i have taken it apart and cleaned it 3 times (a real pain) and it wont seal back up.  has a slow drip at idle.
Re: XJ
« Reply #31 on: November 12, 2012, 11:15:46 AM »
negative.. last one was friday night 9:50 about the winch...
Re: XJ
« Reply #32 on: November 12, 2012, 11:17:57 AM »
ill check for the listing.. if not quadratec
Re: XJ
« Reply #33 on: November 12, 2012, 11:36:35 AM »
ordered them...
we only had a listing for the main one and im sure i could have matched them up... but i dont need it ASAP..
Re: XJ
« Reply #34 on: November 12, 2012, 07:12:06 PM »
its driveable, and probably fine, but it just has a little seap about a half drip every 10 seconds.
It is locked and out side, FYI.
probably a 30 min fix on the lift.  annoying as hell, but i have it down.
Re: XJ
« Reply #35 on: November 12, 2012, 07:29:11 PM »
Ill drop them off as soon as they come..
Need to get another salvage appointment
Re: XJ
« Reply #36 on: November 12, 2012, 07:31:43 PM »
I welded a broken exhaust hanger back on also.
bumper looks good.  Winch bolts are easy access.
Re: XJ
« Reply #37 on: November 12, 2012, 07:33:15 PM »
Sweet thanks..
I figured it might be easy or hard..
I think I'm going to like rocking this rig..
Just need to balance and allign this guy..
Re: XJ
« Reply #38 on: November 12, 2012, 07:37:45 PM »
not sure how the front mounts are intended to bolt up, i welded in a couple nuts into the unibody rail, and used some of the existing hardware / new grade 8 stuff.
Looked like the truck was hit in the front passenger, once i realized that and banged it back into shape everything lined up a lot better.
Re: XJ
« Reply #39 on: November 12, 2012, 08:15:41 PM »
Cool..
Yeah it was hit.. Thus the different paint and salvage title.
Glas just a hammer un tweaked it..
Re: XJ
« Reply #40 on: November 15, 2012, 09:19:34 AM »
any update on that oring?  it should be about 1/8" cross section and ~2.5" diameter
Re: XJ
« Reply #41 on: November 15, 2012, 03:28:26 PM »
O rings arrived... should be down at South in the AM.. that group is lazy with afternoon runs to the warehouse..
Re: XJ
« Reply #42 on: November 15, 2012, 05:02:33 PM »
cool, ill get it in this weekend.
Re: XJ
« Reply #43 on: November 17, 2012, 11:39:37 AM »
when is south open till on saturday?  If i can get out of work ill shoot over and grab that oring
Re: XJ
« Reply #44 on: November 17, 2012, 12:39:55 PM »
who knows... those fuckers are on my shit list..
