Author Topic: Time for Tons  (Read 126322 times)
Re: Time for Tons
« Reply #435 on: April 13, 2015, 10:59:52 PM »
Got the other side fitted up and tacked on. Made sure everything fits behind the fenders. Started on the bracing. Still looking at options for engine bar.
Re: Time for Tons
« Reply #436 on: April 14, 2015, 12:05:32 AM »
Looks good.  I really like the fact your keeping it behind the fenders
Re: Time for Tons
« Reply #437 on: April 17, 2015, 09:52:53 PM »
Done enough for upcoming trip. Basic, but a good starting point. Need to give some thought to how it will tie into the stiffener plates on the front. But for now, the front structure is at least protected if something happens. Hood closes with a little modification.
SlvrJK
  • Full Member
Re: Time for Tons
« Reply #438 on: April 19, 2015, 08:31:48 AM »
Nice work dude
Re: Time for Tons
« Reply #439 on: May 04, 2015, 03:34:04 PM »
People using recovery winches as suck down: do you ever find yourself in situations where you need to use your winch for recovery but need to keep the front sucked down? Considering something like this:
Other option I came up with was this. Pulley on front axle. Allows the recovery winch to stay as recovery but is generally kind of a claptrap:
Leaning towards first option.
Re: Time for Tons
« Reply #440 on: May 04, 2015, 04:23:29 PM »
WTF is that rolling over on option 1?
option 2 is the way to go if you want to run a suckdown.
Time for Tons
« Reply #441 on: May 04, 2015, 04:36:36 PM »
Piece of DOM. Seems like a good option to me if you're running rope and don't care about giving up the recovery winch during times you need the suckdown.
Re: Time for Tons
« Reply #442 on: May 04, 2015, 05:03:06 PM »
once you have a suck down winch you will realize they are for the birds
so much hassel and after you break the cable 3 times you will give up
Re: Time for Tons
« Reply #443 on: May 04, 2015, 05:12:16 PM »
Also when you need to recover and the winch line is all fucked and also buried inside itself from being slammed on while loose.
Re: Time for Tons
« Reply #444 on: May 04, 2015, 10:38:13 PM »
Alrighty then. Looked, no room for either option at 4.5" lift anyway.
Re: Time for Tons
« Reply #446 on: June 02, 2015, 09:29:30 PM »
Spent tonight mocking up the ram mount. Really wanted to keep the tie rod over the knuckle which makes packaging hard at lower lift height. Contacts the oil pan about the same amount the trackbar does at full bump.
The ram breaking off the axle would be a nightmare. Looking for opinions on schrongness of this mount. Seems good to me tying into inner c and trackbar mount, and will of course have some added gussets where useful.
Re: Time for Tons
« Reply #447 on: June 03, 2015, 07:29:29 AM »
Looks about as good as you'll get with space constraints.  Go with double thick clevis plates on each end?
Re: Time for Tons
« Reply #448 on: June 03, 2015, 09:17:13 AM »
also consider those C's are cast and wont hold a mig weld much
how does the tie rod flop when cycled with load? not too bad?
Re: Time for Tons
« Reply #449 on: June 03, 2015, 09:22:38 AM »
That was my second thought, right after "are you sure that isn't backwards?"
This is for full hydro, not assist. You don't want any slop in there. If there's any way you can get that ram acting on a steering arm, do it. Get a bling passenger knuckle, run the ram to a high steer arm, and hang a mount off the front of the axle where you have a TON of non-cast material to weld it to.
