Author Topic: Time for Tons  (Read 126196 times)
Re: Time for Tons
« Reply #465 on: June 07, 2015, 07:45:40 PM »
Ran and bled tonight. Seems great so far. May need to limit the ram 3/4" or so to keep from stressing things. Took about 10min of cycling to get froth free fluid in the res.
Diff mount. I can see the flange pulled slightly away from casting while welding even with bolts tightened. Not sure what else I could have done. May see if a friend can mill it flat again if it ends up being an issue.
I didn't get the 211 dialed in so they look a little goobery but they are hot. I am not much of an out of position MIG welder.
Need to pull tie rod off to burn in the mount and paint it. Adjust trackbar 1/4" shorter to keep fitting away from pan and full bump. Grind diff cover a hair more to clear tie rod at full driver lock. Then put it all back together.
Re: Time for Tons
« Reply #466 on: June 07, 2015, 08:03:29 PM »
Welds look fine to me!
Re: Time for Tons
« Reply #467 on: June 07, 2015, 09:13:55 PM »
I had issues when I welded a limit strap to the 14 bolt diff cover. Never could get it to seal again.
Re: Time for Tons
« Reply #468 on: June 07, 2015, 09:33:06 PM »
Did it use countersunk bolts? That's the only reason I think I might be ok.
Re: Time for Tons
« Reply #469 on: June 07, 2015, 10:21:20 PM »
RTV it, only lightly snug the bolts, let it dry 24hrs, tighten bolts, fill
or belt sand it or grind it if its super off....
Re: Time for Tons
« Reply #470 on: June 08, 2015, 07:46:55 AM »
No mine didnt.
I noticed those.
I think your right. That could make all the difference.
Time for Tons
« Reply #471 on: June 09, 2015, 09:56:17 AM »
Pulled tie rod to burn in mounting tab and paint. Heim galled up in the tube adapter.
I need to order a collar to use to limit the ram. Last 1" or so is unused when I hit the stops. Dan came over and cycled it while I watched, it does start to bow the tie rod down a little. Holy crap, I did not expect that kind of force from that thing.
Re: Time for Tons
« Reply #472 on: July 19, 2015, 09:53:20 PM »
I see me getting in and out far less frequently during the day now. Haha
Re: Time for Tons
« Reply #473 on: July 19, 2015, 09:59:19 PM »
This thing has turned into Dakota 2.0!
Re: Time for Tons
« Reply #474 on: July 20, 2015, 07:28:24 AM »
What are the buggy guys using for skin mounting tabs?
Re: Time for Tons
« Reply #475 on: July 20, 2015, 07:42:37 AM »
I just got some of these from Ruffstuff
Re: Time for Tons
« Reply #476 on: July 20, 2015, 09:40:44 AM »
i get the ones with out nut serts and just weld in my own nut
Re: Time for Tons
« Reply #477 on: July 20, 2015, 10:25:31 AM »
I don't think I'll ever use bolt on tins again. You'll want to pull them off for cleanup and maintenance but you'll hate having to undo bolts.
I need to dzues my tins. I'm SO tired of bolts.
Re: Time for Tons
« Reply #478 on: July 20, 2015, 11:51:25 AM »
good luck with that and east coast trees
Re: Time for Tons
« Reply #479 on: July 20, 2015, 11:57:54 AM »
Bolts or those Dzus things?
