Author Topic: 571wreck wheel status  (Read 38493 times)
Re: 571wreck wheel status
« Reply #90 on: May 21, 2013, 08:45:25 AM »
i'm planning to stop by m4 after work. i can help if you give me a project
« Reply #91 on: May 21, 2013, 08:53:03 AM »
If you need anything from Vics, I can grab it and bring it up.
I have time to run around this afternoon if you need anything picked up.
« Reply #92 on: May 21, 2013, 09:02:58 AM »
that would be awesome.  i need (2) SPL55-3X Spicer Dana 60 Non Greasable Axle Shaft U Joint 1480 5-806X
F81Z3249AA, SPL553X, 5-806X, 5806X, 5-732X, 5732X,
« Reply #93 on: May 21, 2013, 10:12:06 AM »
I'll be over tonight after work to help out.
I would tomorrow too but I hear a rumor that you'll be out of town? Have to see where things stand tonight and if there are any projects left to work on, trailer stuff maybe?
« Reply #94 on: May 21, 2013, 10:27:09 AM »
probably gona run to buffalo wednesday night to see mom quick. ill be back around 8 or so
« Reply #95 on: May 21, 2013, 12:20:12 PM »
Thats a lot of part numbers.
Heading to Vics now, you just need the 2 joints? I have a set of full circle clips if you would like to use them.
« Reply #96 on: May 21, 2013, 12:30:44 PM »
Actually get three, I have a delco to swap out.  Should be like 35$ or so each I think
« Reply #97 on: May 21, 2013, 01:16:02 PM »
$50 each :o
« Reply #98 on: May 21, 2013, 01:45:10 PM »
I guess they're getting expensive? I couldn't find them on RA, but $39 from JBG
http://broncograveyard.com/bronco/i-11793N-dana-60-spicer-1480-series-axle-u-joint.html
« Reply #99 on: May 21, 2013, 02:16:42 PM »
50$ seems a little marked up lol but sure
« Reply #100 on: May 21, 2013, 02:20:18 PM »
next time ill have them overnighted from drivetrain america that has 32 in stock
hoping for no next time!
« Reply #101 on: May 21, 2013, 03:00:30 PM »
amen
« Reply #102 on: June 10, 2013, 09:07:01 PM »
We talked a bit about your axles' breaking 5.38 and now running the 4.10
Here the link to how to put Dana 70 gears in your Dana 60 housing. Goes by "Jana 76"
http://www.pirate4x4.com/forum/axles-tires-wheels/946421-jana-76-tm-how-install-70s-your-60-a.html
« Reply #103 on: June 30, 2013, 05:44:31 PM »
Almost race prepped.  Psc ram on and bled.
« Reply #104 on: July 01, 2013, 12:23:35 AM »
race prepped, and in great shape a week early.
Alex grabing some bolts for me tomorrow to swap out all link bolts
new steering is nice
bumped rear CO up 1.25" bumped front up .5"  for go fast
rear brake lines fixed
fan wiring upgraded
front pass wheel bearing rebuild after found loose.
grease
tires at 28psi
driver motor mount poly swapped
driver caliper braket shimmed (only mechanical slop found in brake system)
MC bench blead, four wheel brake bleed.  SHIT STANE brakes still.
rear flex 3 way changed
Rear driver bango copper changed and tight
vacated driver lower window net bar fabd
