Author Topic: 571wreck wheel status  (Read 38472 times)
Re: 571wreck wheel status
« Reply #75 on: February 28, 2013, 04:08:44 PM »
there is nothing better the way i drive unfortunately.
i was not happy how fast they wear.
« Reply #77 on: April 04, 2013, 07:50:51 AM »
it sounds like the bigzj xtranormal cartoon lol
I want moon buggy so i can get all the chicks
« Reply #78 on: April 04, 2013, 07:52:33 AM »
ad says no junk :flipoff2:
« Reply #79 on: April 04, 2013, 08:12:11 AM »
22k is about my low end unless parts come off.   18.5k in parts nose to tail.
« Reply #80 on: May 04, 2013, 10:43:33 PM »
After 50 miles of sustained go fast, front shocks luke warm, rear shock so hot I couldnt touch the bodies or resiviors.  Puzzled on that one.   Wondering if nitrogen pressure needs to be checked more often, or rear air bumps are needed.
Brakes and steering still shitty
Gps is AWESOME again.
« Reply #81 on: May 06, 2013, 08:43:44 AM »
both o2 sensors smashed off
driver motor mount 80% material failure around welds.
skid vacated (not recovered from course)
rear pass shock needs looking at, ridding dirty
trans took 2.5 quarts after powerwashing to make truck move
motor took a quart of oil
2hours of power wash and she is ready for some lift time / wreck wheeling.
« Reply #82 on: May 06, 2013, 09:50:26 AM »
Was the fan on low?
« Reply #83 on: May 06, 2013, 09:54:23 AM »
forgot to check
« Reply #85 on: May 21, 2013, 12:01:06 AM »
so sick of this fucking thing i want to be racing my other car.
chassis is broke clear in half on both sides where the sub meets the main rails, looks like its been slamming for a wile with a good beat 1/16" gap
Fawk me.
I can see what Balduci brothers build millers sub out of 188 wall chromolly sleved over solid aluminum.  redoncuoulus.  meh
motor mount area cut out and replaced, masive steel and 3/8"s gussets inplace on drivers side.
« Reply #86 on: May 21, 2013, 07:46:15 AM »
Are you planning on pre-running on Friday?
« Reply #87 on: May 21, 2013, 08:22:55 AM »
Are you going to race it?
« Reply #88 on: May 21, 2013, 08:23:35 AM »
Time for a full tear down and rebuild?
« Reply #89 on: May 21, 2013, 08:43:27 AM »
not happy about a couple loose ears / caps on the front end so that has to come all apart.  going to see if i can source some spicer joints today to have, and piece together some good shafts or put the RCV's in
fix front axle shaft situation
fix frame, gusset failure
make skid
put a new O2 on
prep the rest of the car
