Author Topic: 571wreck wheel status  (Read 38470 times)
« on: August 22, 2012, 11:57:19 AM »
man this was painful, almost off the lift haha
swapped on a spare CO, changed the springs and such into the back,
disconnected both rear calipers and bled out the master for front function.  washed and cleaned, front skid wreck removed, need to start over on that one.
headlights
rear bushings
some wireing issues
« Last Edit: August 22, 2012, 04:20:59 PM by M4wdFab »
Re: 572 wreck wheel status
« Reply #1 on: August 22, 2012, 12:18:09 PM »
want my other 2 KCs for head lights?
those rear bushings are the worst I've ever seen!
« Reply #2 on: August 22, 2012, 12:26:56 PM »
ill take a look if its electrical or not why the one doest work.
i should get a couple LED lights from Matt anyway.
« Reply #3 on: August 22, 2012, 12:36:55 PM »
572?
Re: 571 wreck wheel status
« Reply #4 on: August 22, 2012, 12:48:39 PM »
ha, opps ya 571, dam cars.
« Reply #5 on: August 22, 2012, 12:58:18 PM »
Ha, getting ahead of yourself there.
« Reply #6 on: August 22, 2012, 02:15:30 PM »
Haha I have glued both my fog lights back together. I should put an order in as well.
Re: 571wreck wheel status
« Reply #7 on: August 30, 2012, 04:04:15 PM »
14.5 gallons last race used  50 miles
at least 3 laps in full low range winding motor out a little more than usual
« Reply #8 on: October 08, 2012, 09:30:12 AM »
how are my shocks coming along?
if they are whooped ill just take two new ones.
something is broke in my driver rear, its just slamming-  its the gif shaft one and the lower seal is stripped out of the body, looks like oil is all gone too.
« Reply #9 on: October 08, 2012, 09:34:40 AM »
Got my shipment in on Friday, I will have them ready this week. They are whooped, but I can fix them up. Well, except for the dual rate stops, those are gone and the threads are whooped, at least on the one. I did not closely inspect the other.
« Reply #10 on: October 08, 2012, 10:26:53 AM »
are you coming to the meeting tuesday?  bring two new ones for me?  fix what you can later for spares?
« Reply #11 on: October 08, 2012, 10:38:39 AM »
I do not know for sure if I am coming. I will try. I will bring new ones for you if I can make it up.
« Reply #12 on: October 08, 2012, 09:07:51 PM »
I got one of yours apart and fixed, ran out of lock tite and shock oil, after the shock fell over and spilled oil all over my floor.
« Reply #13 on: October 08, 2012, 09:08:36 PM »
The other one is not coming apart very well.
« Reply #14 on: October 08, 2012, 11:24:58 PM »
i have a half gallon of king oil
