Author Topic: 571wreck wheel status  (Read 38538 times)
Re: 571wreck wheel status
« Reply #30 on: January 12, 2013, 08:51:24 AM »
6 bolts and and crack a break line is all it takes right now.
i think it will get done.
im not worried about it cracking, just its wore 1/2 way though the bottom bolt threads.
« Reply #31 on: January 12, 2013, 08:37:36 PM »
Let's get this PIG done. RAUSCH IS CALLING!
« Reply #32 on: January 14, 2013, 12:21:10 PM »
14 bolt is pulled and on the bench, will finish adding back steel and try to get her back in tonight.  Fluids and prepped tomorrow.
« Reply #33 on: January 14, 2013, 11:25:59 PM »
man, needs a 4th night. it is killing me
front shafts ujoints changed, spares prepped for both sides
front and rear 4.10 gear setups done
14 bolt pulled and plated and re installed
Front end assembled 100%
just need drive shafts put back in, fluids put in diffs, a brake line hooked up and bled, tins, under hood fluids, and tools packed.
maybe a wash or dirt scrap
« Reply #34 on: January 15, 2013, 11:31:00 PM »
loaded in trailer
feels like a tbi again with 4.10;s
sad face.
Lifetime LED light is sickk!
« Reply #35 on: January 26, 2013, 12:02:02 AM »
on the lift.  MEh.
« Reply #36 on: January 26, 2013, 07:29:21 PM »
New 60 on.  High steer arm bent!
« Reply #37 on: January 27, 2013, 01:25:50 AM »
done and back in the trailer.  shitty brakes still.  got some air out of the front driver that made it much better to typical 1.5 pump
« Reply #38 on: January 27, 2013, 09:09:46 PM »
What? You bent the solid High Steer arm?
« Reply #39 on: January 29, 2013, 09:06:50 AM »
ya, its got about 3/8" of an inch arc up in the center when you lay it on the bench.  driver heim was all bent up too.   i had to disassemble to get it bolted back up
« Reply #40 on: January 29, 2013, 07:23:44 PM »
Wow.
« Reply #41 on: February 09, 2013, 12:28:34 PM »
« Reply #42 on: February 09, 2013, 10:45:46 PM »
This guy jumps a lot better with a new knuckle.
snow banks are fun.
« Reply #43 on: February 10, 2013, 07:16:40 PM »
she is back to full duty.
turns Rs like a sunday drive.
« Reply #44 on: February 11, 2013, 09:32:42 AM »
Yes she does.
How much air u got in those Swampers? :o
