Author Topic: 571wreck wheel status  (Read 38535 times)
Re: 571wreck wheel status
« Reply #15 on: October 08, 2012, 11:28:02 PM »
on the lift, has new rear calipers and rear bushings.  4 links are tight, needs diff service, some rear brake lines run, and studs to mount up TLS's
« Reply #16 on: October 08, 2012, 11:30:30 PM »
tell me no!  (30)  44" blems available....
BOG-45 NON HIGHWAY SERVICE BOGGER       18/44-16.5   30   $435.00
« Reply #17 on: October 09, 2012, 12:13:54 AM »
Does than mean stickies???
I think that means stickies.
« Reply #18 on: October 09, 2012, 07:53:12 AM »
i dont think so, i think that just means they are square
also trying to get a better price from lou on some 43's
« Reply #19 on: October 10, 2012, 10:37:13 PM »
rear calipers installed
new rear hardlines
brakes bled, still suck
front hubs serviced, decided on 4 longer wheel studs improperly pressed in, with 4 shorter studs on each side.  wheel spacers and TSLs mounted.
need to replace rear coil over, tie up some lines, do some fluid changes, pack tools and swap to 42 spare
« Reply #20 on: November 12, 2012, 07:08:33 PM »
this thing amazes me, it will be tough to let go.
it just takes a beating, and my mercy ran out long ago.
« Reply #21 on: November 12, 2012, 07:19:30 PM »
She amazes me too!
That was alot of whoopass applied Sunday! And she didn't even hiccup!
« Reply #22 on: November 12, 2012, 07:26:48 PM »
i try to push 2x as hard wreck wheeling than racing.  its the only way to finish races and learn your level.
The car has gotten about 2 days of prep in the last 6 wreck trips, and just keeps taking it.
« Reply #23 on: January 09, 2013, 12:26:50 AM »
pulled this guy apart tonight to replace the blown shaft...
front ring and pinion blown also!
b itch
« Reply #24 on: January 09, 2013, 09:55:19 AM »
i have 2 expired gift certs to this place for the club running adds on the site.
wonder if they would honor.
http://www.streetsideauto.com/p/g2-axle-and-gear-2-2034-538/?utm_source=googlepepla&utm_medium=adword&utm_content=pla&gclid=CNOW7OfD27QCFYVFMgodKn4AZg
« Reply #25 on: January 09, 2013, 04:00:25 PM »
hmm summit has the item.  i might call and see if they will honor there price match / beat policy.  looks legit same item.  but i know summit will ship it.
http://www.summitracing.com/parts/gta-2-2034-538?seid=google&gclid=CPy5u42V3LQCFegWMgodlx4AFQ
« Reply #26 on: January 10, 2013, 12:35:46 AM »
eh, all the parts i need were gathered tonight
she is going back to 4.10's for now.
« Reply #27 on: January 10, 2013, 11:21:30 PM »
4.10's in the front with new joints in shafts.
rear 4.10's is on the list for tomorrow with fluids and wrap up on both ends.
« Reply #28 on: January 12, 2013, 01:09:52 AM »
she is a fully 4.10 geared machine.
no ambition to wrap up.
debating to pull the 14 to the bench and add 1/2" to bottom thats GONE
« Reply #29 on: January 12, 2013, 07:56:04 AM »
Probably not a bad idea to plate a thin diff. Would suck to crack it, just as much as it'd suck to crack the front. Also just as annoying to fix :)
