Author Topic: 571wreck wheel status  (Read 38450 times)
Re: 571wreck wheel status
« Reply #105 on: July 01, 2013, 12:26:03 AM »
PSC in and tight
« Reply #106 on: July 01, 2013, 08:23:07 AM »
I have no ideas on why the brakes are shitty. That sucks. My only thought is that it may be related to actually having flow to the rear. The crushed SS line may have been acting like a residual valve?
« Reply #107 on: July 01, 2013, 09:22:06 AM »
speaking of the crushed SS line- that got replaced with a rubber line.   i was thinking this system has 8 rubber flex lines.... maybe too much for the displacement of the MC?
thats what it feels light to me- just not enough stroke to make pressure.
« Reply #108 on: July 01, 2013, 09:50:54 AM »
There is no residual valve?
« Reply #109 on: July 01, 2013, 10:08:37 AM »
never, not on anything i have ever owned or worked on.
« Reply #110 on: July 01, 2013, 11:45:35 AM »
i have a corvette 1 1/8 bore MC
Going to try to get Dorman M39324 which is chevy 1.25" bore
or M390530 which is ford 1.375" bore
« Reply #111 on: July 01, 2013, 11:48:07 AM »
Seems reasonable.
« Reply #112 on: July 01, 2013, 12:16:20 PM »
found cardone 10-1584 with a 1.330 bore for 24$ at advance
gona try it.
« Reply #113 on: July 01, 2013, 01:03:43 PM »
thing is large lol.  no idea if it will fit under the hood haha.  looks like same hydralic outs.
Also just thought of something, i wonder if that line lock is F'd up.  it hasent worked in a while.  I think thats going to get take out also.
« Reply #114 on: July 01, 2013, 01:24:39 PM »
hood there doesn't seem important ;D
I don't think those symptoms could result from a fubar line lock but it really isn't doing much these days so fuckit
« Reply #115 on: July 01, 2013, 01:43:03 PM »
Sorry I meant proportioning valve
« Reply #116 on: July 01, 2013, 02:58:46 PM »
and my same answer-  proportioning valves are a myth in a 4wd locked truck.
want brakes and all the brakes i can get from any corner.  never run proportioning valves.
« Reply #117 on: July 01, 2013, 03:47:25 PM »
I could see your point if you where running all the same caliper on all four corners but with a proportioning valve could you use that to "set or plant" the front end in a corner better since they are 70 front / 30 back bias?
« Reply #118 on: July 01, 2013, 03:53:30 PM »
front and back are locked together. No differentiation aside from driveline slop of well less than half a tire rotation.
« Reply #119 on: July 01, 2013, 04:07:26 PM »
its more like 5% of a tire rotation.  watching all 4 tires lock in a controlled slimmy creek slide shows this :)
