Author Topic: Land Rover 109  (Read 61621 times)
Re: Land Rover 109
« Reply #210 on: September 25, 2016, 08:44:00 PM »
While the rear axle is out I picked up a new rear hose, made some brakes pipes, and am in the process of painting the various brackets.
It all went down hill when for some reason I decided to remove the rear shackles from the frame mounts.
Needless to say Im 1/4 of the way in on the rear frame bushings.
Chewed the rubber out of one and have to grab the air hammer tomorrow.... Hopefully these won't hold me up.
This wasn't exactly the way I envisioned spending time with the truck...
Re: Land Rover 109
« Reply #211 on: September 27, 2016, 10:06:18 PM »
Old bushings chewed and knocked out, new plolurathane ones to match the front installed...
shackles painted and new SOLID cover arrived.
Waiting on LR brake parts and a call on actual axle :-\
Re: Land Rover 109
« Reply #212 on: October 01, 2016, 12:40:39 PM »
Picked up the axle yesterday afternoon and got it all settled in the truck last night..
little bit of bearing and race drama I was thankfully able to solve..
I guess the Brits shim this carrier on the bearing side of the race, not the cast iron side..
thankfully Timken makes both American and British "D60" races.. just took a little digging..
some exterior upgrades to keep it full of oil and hopefully leak free, included an updated pinion flange from a defender..
2 hrs. soup to nuts, including a quick on the lift run in...
Re: Land Rover 109
« Reply #213 on: October 21, 2016, 09:38:28 AM »
when it rains hard and steady it puts my gearbox leak into perspective...
 its not the biggest leak in the truck..
rear axle running strong.. truck running well.. time to upgrade something ::)
Re: Land Rover 109
« Reply #214 on: October 21, 2016, 10:05:36 AM »
how about a sway bar so it doesnt drive like a yoyo or am i just that fat on one side lol
Re: Land Rover 109
« Reply #215 on: November 08, 2016, 10:09:41 AM »
upgrades present themselves...
broke the rear upper shock mount this AM..
going to have to drive home and evaluate later... :'(
Re: Land Rover 109
« Reply #216 on: November 09, 2016, 09:20:47 AM »
Broke clean off...
still DD status for the moment..
jacel86
    • Tallmadge Tire
Re: Land Rover 109
« Reply #217 on: November 09, 2016, 10:25:06 AM »
Mmmm crusty
Re: Land Rover 109
« Reply #218 on: November 09, 2016, 10:51:25 AM »
yeah..  but frame isn't punky there at all..
I think I either need an M4 shock location redesign or to go back to some "stocker" gas shocks..
Re: Land Rover 109
« Reply #219 on: November 09, 2016, 09:17:25 PM »
needs less bush mechanic welds
Re: Land Rover 109
« Reply #220 on: November 14, 2016, 02:33:39 PM »
Finally got a jack permanently mounted in the rover.
baby hi-lift fit perfectly behind 2nd row, handle mounted out of load space.
Its just enough to do a roadside tore change..
Re: Land Rover 109
« Reply #221 on: November 16, 2016, 11:40:28 AM »
doing some rear shock figuring tonight..
got some Jeep parts to throw at the rover suspension  :o
not a whole lot of room to relocate upper mount..
Driveshaft also a limiting factor since it passes through the chassis..
Re: Land Rover 109
« Reply #222 on: November 19, 2016, 02:49:32 PM »
installed an anti mistake mechanism on the koenig...
now that the driveshaft is in, I have been cautious of walker byers that might have fiddled with the controls.
jacel86
    • Tallmadge Tire
Re: Land Rover 109
« Reply #223 on: November 19, 2016, 02:59:18 PM »
Smart.
Re: Land Rover 109
« Reply #224 on: November 22, 2016, 09:05:10 AM »
I need an education on shocks..
or these guys help... http://justacarguy.blogspot.com/2016/11/i-dont-think-ive-ever-seen-shadetree.html
driving around for the last couple weeks minus one rear.. some wheel hop and vibration at WOT, but were dealing with >100 HP here..
The rear of the rover is limited in articulation due to the DS passing through the frame..
I'm ok with that.. were not flexing to impress the ladies here.
With the truck stationary I have a measurement of 19" between shock mount points.
I have been having a hard time finding a shock that satisfies the compression and extension that I want.
where do I sacrifice?  or do I just need to spend more time on bump stops and limit straps?
