Author Topic: 572  (Read 413142 times)
Re: 572
« Reply #960 on: May 13, 2014, 04:27:18 PM »
Re: 572
« Reply #961 on: May 13, 2014, 04:30:42 PM »
Re: 572
« Reply #962 on: May 27, 2014, 09:20:08 AM »
weekends toll:
broken Lii mirror glass
ripped front bumper off
radiator fan locked solid!
Re: 572
« Reply #963 on: May 27, 2014, 01:24:34 PM »
Yea that was a rough day.
Re: 572
« Reply #964 on: May 31, 2014, 06:39:50 PM »
Pretty good power slide roll
« Last Edit: May 31, 2014, 06:41:30 PM by M4wdFab »
Re: 572
« Reply #965 on: May 31, 2014, 07:42:43 PM »
Who ever said Whispering Pines was boring wasn't watching sMike perform.  Awesome!  Belts, cage, and vents did their job well.
Re: 572
« Reply #966 on: May 31, 2014, 09:39:24 PM »
user error
3/4 roll coming in hot
knocked head, both knees, left elbow and crushed my hand a little.  was lucky as the car rocked from its resting place i was able to reclaim my hand back
A to B on the left side of the car that took the brunt of it is frowing 3"
"X" in roof is a little visible pressed into aluminum!
should have had my shoulders on and that was stupid.
Re: 572
« Reply #967 on: June 02, 2014, 10:49:05 AM »
water proof switches next day'd
Re: 572
« Reply #968 on: June 02, 2014, 11:49:35 PM »
Artec arms, bolt tie in kits, and king pin spring eliminators installed.
shit is HD and took a little bit of muscle to get it on but all good.
both king pin bushings were exploded and bits.
Re: 572
« Reply #969 on: June 03, 2014, 08:16:11 AM »
it seemed to be ok with exploded KP bushings?
like you said, bronze would be nice, but having a little give somewhere in the system is probably good. since the nylon ones  are a $3 part, might just be a replace every 2 races kinda thing.
Re: 572
« Reply #970 on: June 03, 2014, 08:48:57 AM »
Looks good.
So it has a bronze bushing in there?
Breaking things to get give where things should be tight doesn't seem ideal to me. I like the idea of bronze and no springs for tight steering all the time. It's not like that 1/8" or less of give when the plastic shatters is going to help prevent catastrophic failure.
Re: 572
« Reply #971 on: June 03, 2014, 09:06:35 AM »
still have nylon, but no springs.
I didnt really know if it was fine because of the 10 degrees toe out i still had.
There is nothing else to break in my front axle other than the spindle, and that means RCV shaft damage most likely- bah.
Re: 572
« Reply #972 on: June 03, 2014, 09:48:09 AM »
I bet spindle bolts would break before the spindle, but maybe not with that deep shoulder?
Probably bend the spindle first and not know it until the bearings explode...
Re: 572
« Reply #973 on: June 03, 2014, 02:56:18 PM »
id bet spindle tube failure before 6 hardened studs let go out of solid knuckles.
wheel spacers and shallow backspace don't help the situation.
need to hit fastenal for 4 bolts- the existing fine thread 1/2" high steer bolts are two long in the Key way positions, need more thread, and shorter.
Re: 572
« Reply #974 on: June 04, 2014, 09:37:00 AM »
Race tires swapped on
Full tin strip and bath
Water oroof switches installed
collector gasket changed
Coolant topped off
front bumper beat back into spec
Running for hardware and parts to do air filter relocation tonight
small list of of prep items
