Author Topic: 572  (Read 413430 times)
Re: 572
« Reply #945 on: May 09, 2014, 12:33:07 AM »
F this pile
Re: 572
« Reply #946 on: May 09, 2014, 07:49:00 AM »
Glad I'm not the only one
Re: 572
« Reply #947 on: May 09, 2014, 07:59:22 AM »
2nd time the car has sat for 3 nights, and then i have 2 issues before i can even load the car.
fuel pump switch is dead, now 2 switches are dead on the pannel  need to rebuild with water proof switches.
forgot about my missing trailer bearing cap.  went to 3 places no luck.  made one.
fixed broken trailer wires for light issues
loaded / fueled and packed minus cold food in shop fridge / ice.
Re: 572
« Reply #948 on: May 09, 2014, 08:02:30 AM »
no good
Re: 572
« Reply #949 on: May 09, 2014, 08:07:20 AM »
Tractor supply has trailer bearing caps
Re: 572
« Reply #950 on: May 09, 2014, 08:09:36 AM »
it was 8:30 by the time i hooked the trailer and realized i forgot about the cap all this week.
Re: 572
« Reply #951 on: May 09, 2014, 08:25:48 AM »
Fuel pump switches are silly. Let the ECU do work! then have a selector switch if you want dual pumps. 2¢...
Re: 572
« Reply #952 on: May 10, 2014, 10:53:13 PM »
ran 4 hard laps.
piled in a tree hard.  REALLY HARD.  felt fine, then noticed car was squirly and going strait driver side wheel was towed out 20 degrees  limped a little 5th lap with a motor that was starving with a caked air filter.
solid high steer arm looks like a candy cane.  no other damage.
over heated motor from my paper towel stash clogging up the front of the raidiator.
was passed by about 4 cars on course.
go pro lasted entire race but was mud covered in the first 3 min.
Re: 572
« Reply #953 on: May 12, 2014, 09:42:13 AM »
needs more motor and a built trans, better mud protection.
some front shock tuning would help also.
i hit 46mph on the cobble stone chop straight in front of the pavilion, and that was comfortable enough to look at the gps....
Re: 572
« Reply #954 on: May 12, 2014, 09:27:59 PM »
yup if they can build it i can bend it.
Re: 572
« Reply #955 on: May 13, 2014, 07:35:15 AM »
stop running into trees!
Re: 572
« Reply #956 on: May 13, 2014, 08:49:03 AM »
Might as well cover your buggies with a sweet plaid paint scheme, for they be lumberjacks.
Re: 572
« Reply #957 on: May 13, 2014, 11:53:33 AM »
starter motor has been flakey after last two races.  clicked 2twice then fired to pull out from trailer.
Re: 572
« Reply #958 on: May 13, 2014, 02:17:07 PM »
Wouldn't it just be easier to admit you want new high steer arms?
Re: 572
« Reply #959 on: May 13, 2014, 03:41:12 PM »
upgrades ordered already, so no.
