Author Topic: M4wdriveway Yota Exo  (Read 139935 times)
Re: M4wdriveway Yota Exo
« Reply #330 on: May 02, 2013, 12:53:31 PM »
duct tape :o
« Reply #331 on: May 02, 2013, 01:29:11 PM »
$20 to UPS ground that thing ummmmm no
what the hell are they smoking???
« Reply #332 on: May 02, 2013, 02:47:19 PM »
I have a fuel pressure gauge that you can borrow. It's a tester kind that hoes on the Schrader valve.
« Reply #333 on: May 02, 2013, 02:50:22 PM »
Is that standard?  I remember reading that something that you need some odd sized fittings and adaptes.  I read it on pirate it must be true!
« Reply #334 on: May 02, 2013, 02:55:56 PM »
I have some adapters with it.........?????????????/
« Reply #335 on: May 02, 2013, 03:06:28 PM »
I'll give it a whirl.  Yesterday was actually the first time it did it at home, so that probably wont happen again haha.
BTW last Thursday was the one year anniversary of this thing running like shit  ::)
« Reply #336 on: July 12, 2013, 11:35:02 AM »
any local wheeling going on soon?
I need to run this hog again after it actually ran last time out, just to confirm it is still a pile.
Matt may have parts I can swap about a month ago or so and I have completely failed on following up on that  ???
« Reply #337 on: July 12, 2013, 11:57:24 AM »
yup....
You got the FLX picnic coming up at Jared's  Aug 10th I think.
« Reply #338 on: July 12, 2013, 12:29:39 PM »
my pile is broke
« Reply #339 on: July 12, 2013, 12:46:23 PM »
I wouldn't mind driving my junker around some.
« Reply #340 on: August 30, 2013, 01:55:02 PM »
I have got to fix this thing or do some thing with...
Lets review
Symptoms:
Diesels randomly, key cycle its back for an undetermined amount of time.  Seems more prevalent uphill.
Non fixes:
swapped fuel pump
full tune up + coil
some sensor in the front I forgot temp sensor (was a code)
swapped ecu
new o2  (was and still is a code with new ecu)
no visible wiring issues
have a JY regulator but I cant get the old one off
To check:
1. oil in the distributor?  I have no idea what this means along with 85% or what fasteddie posted on flx, but I can check lol
2. fuel pressure?  Gauge requires some sort of banjo T adapter fitting thing. no longer available from toyota.  LCE sells a kit w gauge for $60.  I need a man to come over and swap that regulator ::).  Is there some sort of obd1 scangauge thingymabober out there?
3. Spark?  I'll get a checker
4. vacuum?  I suppose I could just replace all the hose for like $5
5.  propane swap is expensive anyway you look at it, plus I dont want it.
anything theories?
« Last Edit: August 30, 2013, 02:00:15 PM by etk300ex »
« Reply #341 on: August 30, 2013, 02:03:54 PM »
gauges on fuel and vacuum would be most useful next steps.
I bet we can junkyard something for much less than $60 to get on the fuel system.  If we can makes a 1/8NPT home somewhere I have the 60psi mech gauge on a 24-36" lead from Smike that was on dumpbus.  if dumpbus parts don't make it run right NOTHING can.
« Reply #342 on: August 30, 2013, 02:22:08 PM »
this is apparently the only way to do it without doing some drilling and tapping.  Keep in mind every bolt on this engine is perma rusted :-\
Quote
Fuel Pressure Gauge Kit 22RE
Ever wonder if the fuel regulator is doing its job? Not sure if your getting the right fuel pressure at the fuel rail? The new fuel gauge kit is the answer to those questions. This kit will replace the banjo bolt on the cold start injector with a new stainless steel bolt that accepts a 1/8 NPT gauge that comes in this kit. Included in this kit is the copper crush washers, elbow to face gauge forward, and 0-100 PSI Silicone Filled for Vibration Dampening Gauge that is 1.5".
« Reply #343 on: August 30, 2013, 02:23:27 PM »
suppose I could check injectosr too, just pull the connector off and see if change right?
« Reply #344 on: August 30, 2013, 02:26:01 PM »
wh wait
cold start injector? huh?
