Author Topic: M4wdriveway Yota Exo  (Read 139925 times)
Re: M4wdriveway Yota Exo
« Reply #315 on: May 02, 2013, 09:47:09 AM »
Those motors came carb'd, right? How hard would a carb/propane conversion be?
« Reply #316 on: May 02, 2013, 09:52:26 AM »
Bring it over we can smash it up with the big bore
« Reply #317 on: May 02, 2013, 09:57:11 AM »
It's efi
« Reply #318 on: May 02, 2013, 09:58:16 AM »
Right, so throw a carb on it, propane and done? Idk about ignition though
« Reply #319 on: May 02, 2013, 09:58:57 AM »
Sorry, probably a useless suggestion you would have considered by now if it was viable hahaha
« Reply #320 on: May 02, 2013, 09:59:17 AM »
ya need good ignition system.
i could make that motor run on pane in 20 minutes if the ignition system is good...
« Reply #321 on: May 02, 2013, 10:03:54 AM »
To make it carbed or propane it needs a distributor from a 22r, and I would assume some type of intake manifold as well.
« Reply #322 on: May 02, 2013, 10:22:02 AM »
Yeah it's not that easy.
« Reply #323 on: May 02, 2013, 10:22:28 AM »
I did pull plug wires, they were all firing.
« Reply #324 on: May 02, 2013, 10:25:05 AM »
I'm pretty convinced its fuel related.  I suppose I should inspect the injectors.
« Reply #325 on: May 02, 2013, 11:39:44 AM »
put a fuel pressure gauge on the rail.
swap injectors from a happy truck if they're not a Delphi item.
what's in your ignition system? ICM, coil, distrib, plugs? I'm sure you've already done the tuneup items. Should be able to throw a generic coil in there for cheap. that'd leave the ICM which I thought was already suspect #1
« Reply #326 on: May 02, 2013, 12:23:47 PM »
all brandy new except the ICM which is a whole lot of money
fuel pressure kit from LCE has come down in price quite a bit since last year, guess its time to get it  http://www.lceperformance.com/Fuel-Pressure-Gauge-Kit-22RE-Fuel-rail-p/2019128.htm
« Reply #327 on: May 02, 2013, 12:42:41 PM »
ductaping a mixer to the TB and unpluging the injectors will make it run fine temporarly
« Reply #328 on: May 02, 2013, 12:43:35 PM »
might have to plug 4 dummy injectors to show good resistance on the harness
« Reply #329 on: May 02, 2013, 12:50:40 PM »
$20 to UPS ground that thing ummmmm no
