Author Topic: new house for mikemike  (Read 228632 times)
Re: new house for mikemike
« Reply #555 on: April 05, 2021, 07:32:53 AM »
Power was out for almost 2hr last night. Lit a fire and checked water meter. Water powered sump pump used 30 gallons and let me just go to bed.
Win
« Reply #556 on: April 05, 2021, 08:15:51 AM »
what took power out in your area?
regards the willow tree, do you have a branch or two I can have? I read that stab a twig or branch into ground will grow roots and make for another tree. They love water and will suck ground dry, which I need, by my mailbox.
« Reply #557 on: April 05, 2021, 08:31:20 AM »
Plenty of live cuts available any time. And yes they will root with no effort. Some drops will start growing roots in a puddle.
No clue on what had power out. Looked like it was just me.
« Reply #558 on: April 07, 2021, 04:20:07 PM »
burned a bunch of propane with the floor heat turned up yesterday and have a general idea of the layout in the slab. It's not super easy to see them, there's only a 5-10F at most difference.
There were no warm spots near the axle rack at all, so looks like I lucked out. I'm surprised at how far apart they seem to be. I wonder if some of the lines could be plugged? Was hard to see the return manifold temps with the hot of the feed manifold tight behind it right there.
camera is slow to update and low res but seems to do its job. For the price, would be nice if it were nicer but that seems to be what is. I saved a bunch of shots, will upload sometime.
« Reply #559 on: April 07, 2021, 07:27:46 PM »
Tubing could be spaced as much as 12-18" apart depending on diameter. Each loop layout also could be more of a spiral than ladder(?).
« Reply #560 on: April 07, 2021, 07:53:24 PM »
Loops with that spacing and then blanks 4-6' or even 10'.
only better test might be to close one loop at a time so full boiler output goes to each one in turn?
« Reply #561 on: April 07, 2021, 08:26:16 PM »
This. Also, get your driveway chalk out and mark 'em.
« Reply #562 on: April 07, 2021, 09:33:12 PM »
Didn’t hit anything.
« Reply #563 on: April 07, 2021, 10:16:38 PM »
Done.
Tire rack next.
« Reply #564 on: April 12, 2021, 07:56:56 AM »
Loaded the rack Saturday. Worked out pretty well with one exception: I can’t reach the top shelf with the forklift. Oops
1.45” rain yesterday brought the pond up 8”. Overtopped banks again. I need to make my outflow wider apparently.
« Reply #565 on: May 06, 2021, 08:16:47 PM »
Glad I mowed before the rain tomorrow so the yard is dry! Lol
« Reply #566 on: May 07, 2021, 07:48:28 AM »
Haha
« Reply #567 on: May 07, 2021, 03:05:10 PM »
i just beat the rain by about 30 min today when i mowed.  happy about that!
« Reply #568 on: June 21, 2021, 03:11:41 PM »
shop is holding 74 right now with light off. was the same yesterday. shop office down a couple degrees since I opened the doors to the shop. I've left the ceiling fans on, so it should be pretty mixed.
90 at ground level outside and 85 up the pole at the weather station.
« Reply #569 on: June 21, 2021, 06:38:09 PM »
One pro to having a small shop
