Author Topic: waste oil burn  (Read 79067 times)
Re: waste oil burn
« Reply #75 on: December 05, 2020, 05:53:05 PM »
yes a barrel would work fine if its in good shape and doesn't leak.  if its an open top barrel even better.   I have a bunch of 5 gallon buckets with questionable stuff in them but if you solo cup off the top its fine.
Re: waste oil burn
« Reply #76 on: December 16, 2020, 09:17:18 PM »
still cranking  shop was 60 tonight- with about 28 outside, ill take it.
new coleman air pump came in thats a little more CFM that i need to build an adaptor for.  I can tell im losing a little heat through the exhaust fan even with the damper jammed shut with a 2x6.
Re: waste oil burn
« Reply #77 on: January 26, 2021, 03:09:10 PM »
o man.  had an event today!  i did something dumb.  and she blew!   blew shit all the way to my lathe across the shop.  sounded about like a 12 gage where i was standing right next to it!   blew stove door open, blew my clean out hatch in upper drum open, and blew the stack apart in two places like a banana.  flame went out while i was adjusting stuff, i dumped in more kero, and stove must have filled with oil / kero vapor, and it blew when i turned air back on.
security camera footage is excellent.
haven't figured out how to get video off my security drive site though, so phone to monitor lol
https://youtu.be/4BFF9yU5QJw
Re: waste oil burn
« Reply #78 on: January 26, 2021, 03:11:45 PM »
i think the next stove will have a rear facing blow out door.  maybe a few other things.  i now i know not to do what i did.  even though i have done that many times. hmm.
Re: waste oil burn
« Reply #79 on: January 26, 2021, 03:28:10 PM »
Did you have a blowout?
Re: waste oil burn
« Reply #80 on: January 26, 2021, 03:30:34 PM »
damn, you handled that well, not even a flench or a jump
Re: waste oil burn
« Reply #81 on: January 26, 2021, 03:51:29 PM »
Ah, I didn't see post above.  Damn.  Is this unit repairable?
Re: waste oil burn
« Reply #82 on: January 26, 2021, 03:56:46 PM »
ya, i had it back up and running in a half hour.  turned on the shop exhaust fan and shoveled out some soot, decided to clean out the upper drum again and inspect since my inspection cover was blown off lol
couple zip screws and some new foil tape with the scissors lift, all good.
i am down to my last 5 gals of oil so need more!
Re: waste oil burn
« Reply #83 on: January 26, 2021, 04:00:15 PM »
whole problem was caused by the oil line was plugged/running slow and over flowing the funnel, so i was trying to clean it and unplug while the stove was hot.  flooded the burn chamber with oil, should have let it cool down before re lighting.  bah.
Re: waste oil burn
« Reply #84 on: January 26, 2021, 07:51:53 PM »
THIS! Unfazed!
Re: waste oil burn
« Reply #85 on: January 26, 2021, 07:54:51 PM »
The s in smike is for steady
No flinch was the first thing that struck me too lol
Glad it didn’t go in bad directions. Keep being lucky!
Re: waste oil burn
« Reply #86 on: January 29, 2021, 06:23:57 PM »
beyond my better judgment drove out to Ontario to pick up 7 drums of WMO
got home, found 4 drums of clean used solvent, 1 drum rock solid ice, 1 drum full of WMO and 1 drum 2/3 of WMO with 10" ice block at bottom.
Meh.  bad at this game.
ran a test burn of 50/50 solvent/WMO and seems to burn fine.  research says the fluid is Kensol 30, a mineral spirits or stoddard solvent like i use to use to test injectors lol
Re: waste oil burn
« Reply #87 on: February 19, 2021, 02:12:45 PM »
tried a new blower.  need a bigger one still.
https://youtu.be/-pertXgWaCw
Re: waste oil burn
« Reply #88 on: February 20, 2021, 02:15:40 PM »
Anyway to run more voltage through that pump to get more cfm
Re: waste oil burn
« Reply #89 on: February 20, 2021, 05:45:52 PM »
ordered another one with 120 CFM and rated at higher static pressure.  the wheel blowers really suck with any back pressure.
