Author Topic: MMTR Allroad Idiocy  (Read 42945 times)
wnyjpgy
Re: MMTR Allroad Idiocy
« Reply #30 on: October 15, 2019, 02:56:38 PM »
with all of your VW dealings I'm sure you have the Vag Com software on a laptop? Or a really good scan tool?
« Reply #31 on: October 15, 2019, 04:03:03 PM »
vag-com, yup.
my ram had me wishing I had something more, then I priced a DRB3 and went back to swapping parts to diagnose.
wnyjpgy
« Reply #32 on: October 16, 2019, 09:45:51 AM »
I hear you..
This is what I have, it's older, and the windows boot up is slow, but its been great, updated to model year 18 (last upgrade) and has all of the European software on it as well.
https://www.snapon.com/diagnostics/us/VERDICT
I think I gave $800, still in the case with all of the accessories and manuals.
« Reply #33 on: October 16, 2019, 06:17:57 PM »
Erik and Stef let me know why I was having no craigslist luck on tires (car needs a pair if I didn’t mention).
Local news outlet OWNS classifies there. KSL is it.
245/40r18 delinte d7 https://classifieds.ksl.com/listing/57813683
130 mounted balanced and out the door for a pair. Fuck that stupid tire size but i know it fits as the car sits.
« Reply #34 on: October 16, 2019, 08:36:26 PM »
Facebook marketplace has pretty much taken over everything, Offerup gets some stuff, Craigslist is dead. KSL is more Northern Utah than down here.
« Reply #35 on: October 17, 2019, 12:04:25 AM »
Tons on KSL up in SLC.
I hate fbm. But you’re right. People have no taste.
« Reply #36 on: October 17, 2019, 03:58:22 PM »
Isn't the allroad AWD?   Shouldnt tire size be symmetrical on all 4?
« Reply #37 on: October 17, 2019, 07:52:17 PM »
As compared to the difference between its current bald rears and good fronts.
« Reply #38 on: October 18, 2019, 12:06:03 PM »
ah, didnt realize rears were bald.
« Reply #39 on: October 20, 2019, 09:45:16 PM »
Locked and loaded
« Reply #40 on: October 21, 2019, 03:19:59 PM »
i just realized Allroad is the name of the car
i just thought you meant you accepted all roads lead to idiocy via MMTR lol
« Reply #41 on: October 21, 2019, 06:06:32 PM »
Same here
MMTR Allroad Idiocy
« Reply #42 on: October 22, 2019, 12:19:32 AM »
Hahahahahahahaaaaaa
True.
Bunked out in JT’s trailer. Was a project to swap stock wheels on and that kept me in town*. Capt Rob’s shop to the rescue.
I’m getting rear toe adjusted first thing tomorrow before I leave SLC. I’ll regret it if I don’t from handling/ stability, and I don’t know if tires would make it 2500 miles home without showing cord.
Oil leaks will be dealt with swiftly before dd status. It stinks at idle rest.
It’s also likely gonna get a tune once it’s fully healthy and all basics are attended to. I expect more from 250hp awd 6sp.
Dumpy butt look is even more severe with slightly smaller rolling stock. I don’t know what struts were swapped on but it’s dumb. One could say: idiotic.
*the 18s on it are larger center bore than stock, and it has ~20mm spacers on it which means over length lug bolts. Had to get eccentric ring off spacer to run spacer with stock wheel, or find/ cut shorter lug bolts.
I should have probably put a pair of tires on the rear on the existing wheels and saved the room and weight of hauling 4 tires cross country. Too late now and I didn’t realize the quick fix wasn’t gonna be quick until it was too late.
« Last Edit: October 22, 2019, 12:24:13 AM by mr.mindless »
« Reply #43 on: October 22, 2019, 10:54:27 AM »
One adjuster seized. Hopefull for great improvement. Hitting the road for Moab so I’ll see!
Typical SLC commute view doesn’t suck
« Reply #44 on: October 22, 2019, 02:26:48 PM »
I cant wait to see that mountain range again.  1st week of Nov.
