Author Topic: new house for mike  (Read 158136 times)
Re: new house for mike
« Reply #195 on: June 28, 2019, 01:03:12 PM »
I had a brief brownout overnight tuesday or wednesday. my power is usually rock solid.
surprised I haven't seen a NYSEG notice requesting reduced electrical loads yet today.
« Reply #196 on: June 28, 2019, 01:17:45 PM »
Feed through on a GFI is all good.  These items: (kitchen ceiling light/fan, back stairs hall light) that are on the same circuit as you kitchen counter and ran through the GFI are of concern.
« Reply #197 on: June 28, 2019, 09:04:51 PM »
meh, ill ask JJ when he does my panel if it needs a change.
6 coats and a roll of fiber tap, i was ready for tile today.  took about 3 rum a cokes to decided on the way i was going to do this and well this is what i ended up with for a start.
« Reply #198 on: June 30, 2019, 11:40:14 PM »
what size is the tile?
That shower looks tiny, but photo can be deceiving.
« Reply #199 on: July 01, 2019, 07:16:17 AM »
6x6 tile i cut down to take the pitch.  the walls are 12x12
its super hard to take a picture in a small bathroom haha
its cozy but fine.  shower head got put on that wall because the other wall is an exterior wall and i didnt want that.
« Reply #200 on: July 01, 2019, 09:57:41 PM »
busy night
home for work.
run to Freds garage in Scottsville, pay for international that got a sticker during hours today.  dont swap because i need RAM tonight
back home.  move 48 enclosed and equipment trailer to other side of garage out of lot
prep old Lift and get stuff on a pallet for CL buyer coming tonight.
rock bounce fork lift out of the first floor shop, drive up the road to high side driveway entrance
rock bounce down driveway to concrete pad.  only loose one fork on the way, but dont get stuck.
53' low boy shows up as CL guy shows up.  bah!
do paper work and load and unload both in about 10 minutes.
3700lbs is heavy for 2 bendpack 10k lifts.  about all my forktruck wanted to lift in N with gas on lol
53' leaves, load CL with old lift done deal.
transfer new lifts to ram one at a time, unload in barn with fork jack
rock bounce fork truck back to lower barn and actually not get stuck!
run Ram back to freds for inspection tomorrow, and swap out for IH
food
im tired!
« Reply #201 on: July 03, 2019, 09:44:13 PM »
curb tile done and moved and outlet so i can fix my back splash design. installed a vanity side light.
ready for a little more groute then sealer then done.
paint- i hate painting.  waiting on that.
finally cleaned all the dust out of my kitchen with no more tile and drywall cutting bah!
found exactly the beams i need on FBMP, hoping guy answers and going to run down to PA tomorrow or fri to pick up.
« Reply #202 on: July 07, 2019, 08:54:36 PM »
https://www.homedepot.com/p/GE-100-Amp-3-Space-3-Circuit-240-Volt-Unmetered-RV-Outlet-Box-with-50-30-20-Amp-GCFI-Circuit-Protected-Receptacles-GE1LU532SS/203393689
seems expensive and i need to swap a breaker and a welder outlet in, add another 20 amp breaker.
id like to mount this box or similar outside the barn, feed from existing 200amp pannel in lower barn.  swap the 50amp for a 30 amp welder 220, break the 120 outlet into 2 20 amps and add that breaker.  would be good RV power and welder power out in the lot then.
bah.
« Reply #203 on: July 19, 2019, 11:15:22 PM »
first delco crate of twelve brought upstairs tonight.  forklifts on both floors is so nice. with a truck trip inbetween.
i have  shit ton of work to do in the next 12 days.  hope this knee keeps cooperating lol
« Reply #204 on: July 24, 2019, 09:40:26 PM »
my fed ex girl is cute!
she brough me lots of presents to the shop tonight!
« Reply #205 on: July 26, 2019, 11:51:29 AM »
i put in a 50 amp RV exterior power panel last night
all went well other than finding an easy way though 3' of rock and concrete so i cheated a litttle
anyways-  i go to shut the 200amp breaker off on my main panel before inserting a new 50amp feeder breaker and when it clicked off there was a 2" long blue spark from the back side of the breaker arc'd to the ground/neutral bar next to it.....
what the F just happened?
inserted breaker, hooked wires and all appears well.
« Reply #206 on: July 26, 2019, 12:19:33 PM »
That would be an arc flash.  Very unusual for said actions and equipment.  I'd guess cause would be super dirty or really old and has never been used, or both.
« Reply #207 on: July 26, 2019, 12:51:13 PM »
that sounds scary AF
« Reply #208 on: July 26, 2019, 02:42:15 PM »
i have used the breaker at least 5 times in the last 2 months, this was the first time i recall having the cover off.
o, update its a 150amp breaker not 200.
« Reply #209 on: July 26, 2019, 02:45:33 PM »
i am thinking that when i get JJ to do the house panel when the power is off / meter pulled this main panel is going to get a new main breaker also.
