Author Topic: 1949 chevy 4100: shop rod 2.0  (Read 38741 times)
Re: 1949 chevy 4100: shop rod 2.0
« Reply #45 on: May 21, 2018, 09:55:39 PM »
99% wiring done
pigtails run to all corners for signal lights ect.
3 way flasher and some lights should complete everything.
hope i guessed right on the drive by wire with E38 ECM.  cant really seem to find express van diagrams that are different from truck or car.
« Reply #46 on: May 23, 2018, 10:09:11 PM »
fired first try with PCM back
cleaned up harness and finished under hood
lot tested good to go
new headlights installed
started driver door adjustments, looks like its got some broken bits.
« Reply #47 on: May 24, 2018, 08:49:18 AM »
that's a sexy engine bay
matt
« Reply #48 on: May 24, 2018, 12:05:19 PM »
Nice
« Reply #49 on: May 24, 2018, 10:51:42 PM »
ready for flat bad fabrication this weekend
grote fender mounted signals installed, flasher wired in all good.
« Reply #50 on: May 26, 2018, 09:56:43 PM »
flat bed knocked out today
« Reply #52 on: May 26, 2018, 10:46:58 PM »
Save that for the stake body!!!
« Reply #53 on: May 28, 2018, 08:18:48 PM »
flat bed and hitch finished up today.  gibson exhaust installed.
« Reply #54 on: May 29, 2018, 04:25:07 PM »
hmm, title requires a notory, and a few signatures missing that i need.  bah for rolling the dice at the DMV again for bs answers!
« Reply #55 on: May 29, 2018, 04:50:10 PM »
notary? I know one if you don't.
« Reply #56 on: May 30, 2018, 12:03:01 AM »
tail lights mounted, wiring done, trailer plug mounted and wired
driver door latch 95% fixed
« Reply #57 on: May 30, 2018, 08:31:19 AM »
my bro-n-law just realized that the seller & notary signed the title for the trailer he bought in Ohio in March in the wrong places.. and now he can't get ahold of them.
« Reply #58 on: May 30, 2018, 03:26:35 PM »
might still run through OK if intent is clear. Everything seems to go fine once it's accepted and across the counter at the DMV. Unless it's already been kicked back once or twice... then - that sucks!
« Reply #59 on: May 31, 2018, 07:21:32 AM »
popped rear broken cab glass last night.  installed new rubber seal to settle over night.
