Author Topic: ZJ wonder 5.0  (Read 82870 times)
Re: ZJ wonder 5.0
« Reply #165 on: February 27, 2025, 09:48:44 AM »
no repeated starter motor issues
pass side low beam out noticed last night.  found 2 new bulbs in glove box score!
Re: ZJ wonder 5.0
« Reply #166 on: February 27, 2025, 03:23:55 PM »
headlight bulbs changed, tires aired up, plow removed (last time?)
Re: ZJ wonder 5.0
« Reply #167 on: April 03, 2025, 05:54:16 PM »
3hrs or so of city runarounds today with Chip in this unit, got some sticking calipers putting some major heat into front rotors haha
ordered new front calipers and braided hoses.  probably should get rear calipers and new rotors/pads all around.
still takes overdrive away after about 30 min of driving, and new thing falls to zero oil pressure at idle once hot.  must be a fake FCA gage thing because it would have blown up or started tapping by now lol
Re: ZJ wonder 5.0
« Reply #168 on: April 08, 2025, 07:32:28 PM »
ha
found driver front shock broke free from axle, blown bushing on passenger front ratteling around
changed both front calipers and brake hoses, driver hardline crumbled when i touched it.  changed both sides hardlines. bled
greased all fittings, removed plow frame, changed oil / filter
tied up some hanging trans cooler lines
rear brakes all look shot.  so that will be next time.
Re: ZJ wonder 5.0
« Reply #169 on: April 13, 2025, 10:18:06 AM »
Well I guess whatever I did with the Trans lines I should have left alone.  Looks like it blew as I backed out of lot away from house.  Noticed smoke show pulled I to fuel station, saw garden hose leak of atf everywhere, drove right back home barely and shut it off coasting back to shop.  Left a nice blog trail everywhere.
This may be the end of this thing.  Bah
Re: ZJ wonder 5.0
« Reply #170 on: April 14, 2025, 06:15:01 PM »
i feel mildly better about this now- what i touched and re hung a few weeks ago was not failure point.  hose popped off at trans on other end.
pulled both hoses and added bubbles to hard lines, replaced 2 clamps at each of the 4 locations, new 300psi trans cooler hose.  filled and tested good.
back to full duty i guess again.
not sure im going to order the rear rotors and calipers / hoses it needs.  i think its gotten enough thrown at it for the year.
Re: ZJ wonder 5.0
« Reply #171 on: April 17, 2025, 07:54:46 AM »
i did notice the cirp belt is about to come apart.  found a brand new one in the glove box when i checked to see if an old spare was there or not before leaving on maden voyage with trans lines.
wegmans trip and back no issues.
i guess ill change a belt today bah
Re: ZJ wonder 5.0
« Reply #172 on: April 17, 2025, 05:54:31 PM »
belt changed.  added 10 gals of recovered stale hot rod donar fuel haha
Re: ZJ wonder 5.0
« Reply #173 on: November 10, 2025, 12:07:45 PM »
tossed a battey in, 2 quarts of ATF, and 30$ in fuel for its maiden winter voyage.  i dont think its moved since July when it got taken to the shop for a sticker.
needs brakes all 4 corners.  was expecting a blown line, but no the brakes just suck.
hawged to wegmans and back to get a turkey and some thanksgiving supplies.
lift work it needs: oil change, 4 calipers, 4 rotors, pads, ebrake stuff, center steering wheel, air up tires, clean out organize winter recovery stuff.
Re: ZJ wonder 5.0
« Reply #174 on: November 14, 2025, 06:17:26 PM »
4pad sets, 4rotors, 2calipers, wipers
Re: ZJ wonder 5.0
« Reply #175 on: December 10, 2025, 05:32:36 PM »
plow on.  welded broken plow mount.  fresh section of wire rope for the lift winch
