Author Topic: Troyphy truck  (Read 25634 times)
  • Paying Customer
Re: Troyphy truck
« Reply #165 on: July 27, 2020, 08:53:34 PM »
ill probably run these which are 35's on the street till they are spanked, id like to find a set of 37-39 for wheeling though, but for street ill stay on 35's
Re: Troyphy truck
« Reply #166 on: July 27, 2020, 10:05:01 PM »
needs some 39 BFG KRs to be baller street trophy!
  • Paying Customer
Re: Troyphy truck
« Reply #167 on: July 28, 2020, 06:25:40 PM »
my return fitting on my ps pump is just above the gearbox and is made of plastic,id like to cut it shorter and cap it off, if i do that could i just drill a hole through the cap and stick the return line through it, or would that cause an issue, or is there a better solution?
Re: Troyphy truck
« Reply #168 on: July 28, 2020, 09:22:15 PM »
If you return above the fluid level you’ll aerate the fluid horribly. Bad day.
Almost as bad a day as when that fitting snaps off when the motor moves enough to kiss that weak plastic crap.
Maybe take off whole nipple, tap for npt and put a nipple on a street elbow?
I ran NPT threaded into the stub of a plastic return nipple on my bro for a while. I don’t know if that may have lead to eventual pump failure if it did eventually leak or fail. I put on a TC pump with remote resi. Too many fail points in those plastic things. So I gave myself a whole host of fresh homemade failure points instead!
  • Paying Customer
Re: Troyphy truck
« Reply #169 on: July 28, 2020, 10:23:16 PM »
understood
after some research, looks like i can swap on a bracket from a e-150 or likewise and they run a saginaw pump instead which is a better pump and has metal return fitting out the back of the pump
  • Paying Customer
Re: Troyphy truck
« Reply #170 on: August 10, 2020, 07:02:14 PM »
god i hate wiring ,got a bunch of these to try and do a legit job https://www.amazon.com/gp/product/B0777DY92C/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
got the crimper for them and took me 6 tries to figure how to use it correctly, and FYI when dealing with chinese lights white is ground black is hot
Re: Troyphy truck
« Reply #171 on: August 10, 2020, 09:51:12 PM »
This one took me longer than I are to admit
  • Paying Customer
Re: Troyphy truck
« Reply #172 on: August 20, 2020, 09:21:37 PM »
start of the interior
  • Paying Customer
Re: Troyphy truck
« Reply #173 on: October 07, 2020, 10:18:37 PM »
hopefully the last time i have to pull the motor, underside painted and bedlined,i found an affordable dynamat substitute but with a much higher heat resistance and suitable for firewall and underside coverage as i didnt want to put it inside on the floorboards, i do plan on using killmat on walls and ceiling inside of the cab
Re: Troyphy truck
« Reply #174 on: May 15, 2021, 06:19:35 PM »
update on this hawg?  had to look to page 3 for the thread    ;D
  • Paying Customer
Re: Troyphy truck
« Reply #175 on: May 15, 2021, 08:17:29 PM »
I pushed it out of the garage today, swept around it and pushed it back in. I currently have more money than time, I should talk to you about some work on it when you have time.
Re: Troyphy truck
« Reply #176 on: May 15, 2021, 08:36:39 PM »
lame sauce!
Re: Troyphy truck
« Reply #177 on: May 17, 2021, 08:41:24 PM »
whats left that you need some help with?
  • Paying Customer
Re: Troyphy truck
« Reply #178 on: May 18, 2021, 10:52:18 AM »
Turn signal/hazard wiring, engine wiring and start up,driveshafts,some minor plumbing,shifter installs,rear body panels, and some finish welding and I think that's about it other than cosmetic stuff
  • Paying Customer
Re: Troyphy truck
« Reply #179 on: September 19, 2021, 02:58:03 PM »
i was pretty determined to get the engine to start and run this weekend. i have everything wired and set up, i have spark, i have fuel pressure at the rail, but no start. if i spray fuel in the throttle body it starts and runs, so that was good. im pretty sure i have power to the pcm but im thinking the injectors are not firing or getting a signal. my question is does the computer typically need a signal from the fuel pump that it is on and running for it to start firing the injectors?
