Author Topic: MMTR Mini  (Read 121456 times)
Re: MMTR Mini
« Reply #150 on: June 24, 2015, 11:25:58 AM »
Huge mass difference is key. I think the mini is a potentially great toad.
I flat towed an engineless quad cab 2500 Ram up from NC with my truck when I bought it. It was fine when everything was fine, it was a white knuckle expirience on the road and a broken headlight in a parking lot when it started snowing. Absolutely horrible.
Re: MMTR Mini
« Reply #151 on: July 20, 2015, 11:16:14 AM »
Anyone have any ideas on cutting what's missing on this gear?
Re: MMTR Mini
« Reply #152 on: July 20, 2015, 11:19:20 AM »
wait, the spacer is in place of 4th or the spacer is blocking 4th from being engaged?
Re: MMTR Mini
« Reply #153 on: July 20, 2015, 12:47:35 PM »
you need the syncro set on the right to look the the set on the left.
i think i understand that is part of the gear that the spline isnt cut hmmm.
if i had 2 or three of them id take a cut off wheel too it, but success might be limited.  probably just try and get the right gear to swap onto your shaft that's cut already
Re: MMTR Mini
« Reply #154 on: July 20, 2015, 01:51:47 PM »
I was thinking the same on a cutoff wheel.
the splines aren't cut on the gear. should look like the others.
getting the right gear or even a part number for it isn't easy. There's another guy finally interested in working on it, may make some progress.
I'd like to repower, but I'd rather have a 4th gear if it can be done. Would keep the smoke much more manageable if I can keep RPMs lower. And would give me a workable ultra light duty RWD trans to adapt to another motor if I find one.
Re: MMTR Mini
« Reply #155 on: July 20, 2015, 02:44:24 PM »
how hard is it to take apart the trans to hand one gear thats cut already, and the other one thats not to a machine shop, and how much is it worth to  you?  200-300$?  not sure a legit shop could do that for less.     mill and an indexed angle turn table manually?  maybe something Matt M could do?
Re: MMTR Mini
« Reply #156 on: July 20, 2015, 02:46:44 PM »
Yeah it's not worth real shop rates to me. Probably worth less than $200 to me.
I haven't torn down the transmission. As small as it is I can't imagine it's a horrible job to get it down that far. I'd definitely have to pay attention since I've never taken apart a manual trans before.
Re: MMTR Mini
« Reply #157 on: July 20, 2015, 02:49:42 PM »
What's the manufacture of the teams? If New Venture I can check my gears to see if something happens to be the same. Unlikely.
Re: MMTR Mini
« Reply #158 on: July 20, 2015, 02:51:23 PM »
If you can, measure the OD of the part that needs to be cut
Re: MMTR Mini
« Reply #159 on: July 20, 2015, 02:54:16 PM »
are synchros available for it?
id pull the gear, clamp a syncro to it as a guide and go nuts with a cut wheel in a controlled jiged manner, then taper the teeth as best as possible.  worst you have is something that grinds when attempting to go into 4th.
maybe something can be welded from spencers pile you your gear if it was spun down then pressed together / welded  (using your gear)
Re: MMTR Mini
« Reply #160 on: July 20, 2015, 03:16:14 PM »
Good ideas.
Re: MMTR Mini
« Reply #161 on: September 05, 2015, 03:38:18 PM »
Needs more left-right support. Angle brackets underneath are surprisingly stout fore-aft.
I want to make a mount for the right front corner as well, probably a more common home for it - but more work needed there than here to span the engine cover.
Also, I need a third AC for the garage!
This will be it for today, gotta be at work at 1800.
Re: MMTR Mini
« Reply #162 on: September 05, 2015, 05:22:04 PM »
Fuck halfassing it. Done. Structure welded to the frame under the bed. Well, maybe birdshitted? But it’ll do.
Re: MMTR Mini
« Reply #163 on: November 13, 2015, 06:28:44 PM »
Donor motor found. Check it out Sunday on my way to Cleveland, still in the car – so I even get to test drive it! Pinto 2 L.
Re: MMTR Mini
« Reply #164 on: November 13, 2015, 07:11:07 PM »
1.
Crane looks perfect where it sits.  Nice counter balance to driver and no blind spot issue.
2.
Have a lot of literature on pinto engines.  Use to be a common flat fender swap
