Author Topic: Aussie Locker BRO-LITE  (Read 50595 times)
Re: Aussie Locker BRO-LITE
« Reply #240 on: April 08, 2016, 03:53:26 PM »
ooof!
« Reply #241 on: April 08, 2016, 03:59:27 PM »
Body damage is the worst.  Every panel is damaged. Sucks because we were planning to paint it for this season.
Front end damage looks to be mostly the driver side I beam ( not sure of its proper name)
Most everything else looks ok at first glance. But comparing to new/used stuff will obviously be the true test.
Wish I didn't keep forgetting to pick up my spare set of wheels from M4. Oh and I also loaned the Kubota tractor to a friend before Moab.
Looking like tonight might be Date night instead.
« Reply #242 on: April 08, 2016, 04:02:12 PM »
those tires and wheels are still on my ranger in my trailer.  and i need to find you a replacement tire.  i patched it and it holds air, but no good for anything other than a roller.
we have sets of rollers ill have to swap around.
« Reply #243 on: April 08, 2016, 04:50:39 PM »
K,
I'm hoping the stock LJ wheels will fit to roll the pink truck into the shop tomorrow. I'll get a hold of you if I need wheels sooner
« Reply #244 on: April 08, 2016, 04:52:19 PM »
if i cant find a used tire (matt had one but tread was too low) ill just order a tire for you, found them for 75$ new shipped
« Reply #245 on: April 09, 2016, 02:29:37 PM »
Stock Jeep center bore is too small for front of ranger. But Steel 5 lug trailer wheels fit great!
« Reply #246 on: April 09, 2016, 02:30:01 PM »
« Reply #247 on: April 11, 2016, 10:07:45 AM »
erik, what blade and head size does your tire grover use?    summit Keyser grover says #4?  did you get bigger ones for the boggers?  im looking at getting a setup for bro paddle and rib tires
« Reply #248 on: April 11, 2016, 10:12:33 AM »
8 and 10 ring the bell the boggers were cut about a half inch wide
« Reply #249 on: April 11, 2016, 10:13:56 AM »
Bad front suspension parts removed and awaiting phone call from JJ 4 new axle I beam. They don't seem to be available after market and Ford says they no longer make them.
« Reply #250 on: April 11, 2016, 10:19:54 AM »
found some on ebay, bummer.  looks like truck shopping time.  at least 7 trucks and j/j though  have to be torched out though
« Reply #251 on: April 11, 2016, 10:20:48 AM »
They unbolt from the Frame with 4 bolts.
« Reply #252 on: April 11, 2016, 10:22:27 AM »
Car-parts.com search resulted in a yard in Sodus has 2 of them 125.00 ea
Figured I'd call J&J first before driving to sodus.
Was planning to strip from pink truck out back but then what do I do with a non roller. :(
« Reply #253 on: April 11, 2016, 12:20:29 PM »
I'll buy your non roller, I'm looking for a cab and frame mostly
« Reply #254 on: April 11, 2016, 12:22:07 PM »
Not for sale. Its my back up truck.
