Author Topic: brolite cherry pop 573  (Read 74449 times)
Re: brolite cherry pop 573
« Reply #210 on: May 03, 2016, 11:26:40 PM »
4" xj coils put back in
front shocks lowered 2.5" for more usable down travel
1.5:1 steering quickener and quick disconnect wheel installed
new snow tires mounted.  couldn't come up with a grooving plan, might just leave them.
« Reply #211 on: May 17, 2016, 10:54:51 PM »
New pump, new reservoir, new pulley, new belt, high pressure hose, low pressure hose, cooler deleted.
radiator topped off, oil filled.
needs a battery now also.
« Reply #212 on: May 22, 2016, 10:16:41 PM »
changed out bad ball joints, tightened up both wheel bearings, swapped springs in front for 4' TJ coils, grooved front tires.
need to groove rears, and get a battery then race ready.
« Reply #213 on: May 22, 2016, 10:43:40 PM »
No fire damage?
« Reply #214 on: May 22, 2016, 10:51:31 PM »
fire damage was limited to power steering pump, pulley, belt, hoses.    not too bad. all replaced.
« Reply #215 on: May 23, 2016, 08:59:21 AM »
How were the ball joints to do?
I thought there was something wrong with the 4" tj coils? They sure seemed to work on Eric's truck.
« Reply #216 on: May 23, 2016, 09:52:09 AM »
ball joints easy because you can remove caliper and leave on truck, break free upper and lower, and steering TRE, then move the unit to bench to RxR them.  not bad at all.
« Reply #217 on: May 23, 2016, 09:53:41 AM »
nice.
« Reply #218 on: May 23, 2016, 11:36:06 AM »
i dont know really which coils these are, they are the 3rd set.  seem to give the most travel and bumped up the ride hight a little.  i also set the castor/camber back to zero/zero so its looks much better.
« Reply #219 on: May 31, 2016, 03:27:31 PM »
Erik is running 2" TJ coils
« Reply #220 on: September 04, 2016, 03:52:27 PM »
4 alloy 15" wheels stripped and painted.  new tires and some grooving.
one more jeep on the lift then brolite time
« Reply #221 on: September 04, 2016, 08:44:37 PM »
4 new valve stems installed.
2 rears grooved miller / stowers style.  giving my wrist a rest and will do the steers Tuesday or wednesday
bro pulling into the shop tomorrow.
weight reduction and a few upgrades :)
« Reply #222 on: September 08, 2016, 01:17:36 AM »
front bumper done
right side coil support fixed
new tires mounted
needs:
fuel
fire ext
rear bumper
fluids check
« Reply #223 on: September 13, 2016, 12:22:35 AM »
two more tires ordered
two radius arms and bushings ordered and due tomorrow fed ex.
working on fox  contacts for shocks and shaft replacement.
« Reply #224 on: September 15, 2016, 12:24:00 AM »
tires showed up today
rock auto box with 2 new radius arms and bushings also showed up.
2 day shipping win on that one!
