Author Topic: Brandy new 4500 Cummins  (Read 251012 times)
Re: Brandy new 4500 Cummins
« Reply #15 on: September 29, 2014, 10:38:01 AM »
ATF+4 in the trans
ATF in a manual?  :o
« Reply #16 on: September 29, 2014, 10:41:08 AM »
thats what it says
jacel86
    • Tallmadge Tire
« Reply #17 on: September 29, 2014, 10:54:00 AM »
Dodge is revising a lot of it's manual tranny recommendations. First time I called for the jeep(years ago) it was some silly expensive stuff only they carried. Called again last week and they said atf4 now.
Power mirrors are a lifesaver at ATM's!
« Reply #18 on: September 29, 2014, 11:14:09 AM »
What are your plans with this regarding upgrades and mods?
I'm sure you're going to add a light bar or two :)
« Reply #19 on: September 29, 2014, 11:54:15 AM »
a couple things i dont like with the flat bed mounting / wiring
needs LED white back up / plate lights
forward trailer pigtail is zipscrewed mounted and looks a little hack
pin wood between bed and frame should be swapped for PT
going to add some tool boxes, probably just buy two new matching ones
first and for most needs seat covers.  the truck is high and i really have to roll out of it.  They wont last long with my filth.
a 50" bar will end up on the top of the headake rack, maybe a 10" or 24" facing back also
havent decided yet if it has as much ass as my 24valve.  its hard to tell with the 4.44 gears
« Reply #20 on: September 29, 2014, 12:00:35 PM »
Wouldn't a 50" bar on the headache rack be ineffective because the cab roof would block some of the light's path?  (can't really tell in the pic how high the headache rack is above the cab)
« Reply #21 on: September 29, 2014, 12:29:19 PM »
That is one sweet ride!
« Reply #22 on: September 29, 2014, 01:37:25 PM »
Stupid 4.44s.
You'll run circles around me maneuvering!!!
« Reply #23 on: September 29, 2014, 01:43:15 PM »
I wouldn't run atf4 in the trans. It's a g56, right?
I would (and have, myself) swap that out to Gorilla Juice. Seems to help keep em alive, looks like atf with Lucas in it. Could probably throw a quart of Lucas in there and I wouldn't feel too bad about it. Not sure what sort of trans warranty you're looking at, probably best to run through that with factory suggested fill just in case something happens. Seems a shame to give it the extra wear in the  mean time but I guess it is what it is.
« Reply #24 on: September 29, 2014, 01:44:38 PM »
Changing fluids may void warranty.
« Reply #25 on: September 29, 2014, 01:46:02 PM »
the heads this thing turns is pretty funny.
sweet lunch commuter.  not so sweet to find a parking space at wegmans lol
SlvrJK
  • Full Member
« Reply #26 on: September 29, 2014, 05:05:21 PM »
win
2008 JK X 2-door, 37" Nittos, 3.5" Clayton LA, Prorock 44, Rock Jock 60, and lots of armor...
« Reply #27 on: September 29, 2014, 05:19:11 PM »
lots of middle aged men?   ;D
tony
  • Come and take it
« Reply #28 on: September 29, 2014, 05:48:40 PM »
« Reply #29 on: September 29, 2014, 06:59:32 PM »
pulling duty, ran her first load
6 MTRs lay down on this with pleanty of room to go :)
