Author Topic: 571  (Read 264263 times)
Re: 571
« Reply #1170 on: June 27, 2021, 11:28:09 AM »
2 truck show in unlimited today. The black blazer schooled me.
I was running a little rough and low on power. I have air trapped in the see through fuel filter and see air bubbles in return fuel, I’m certain that’s not good. Will change spark plugs too. Playing with closing return line didn’t make any change.
I want lower effort steering and i think I’m going to do better fluid containment. The balloons get rotted by fluids and then I have gear oil all over.
Something made it feel like a flat for my last lap but all tires are up and all axles are intact.
To actually be competitive I think I need front swaybar, lower it 4”, and better front driveline angles. 60ish or whatever speed at top of front straight has pretty bad driveline vibes. The front two piece shaft is not a CV in the center and only that center joint has much angle at all.
Re: 571
« Reply #1171 on: June 27, 2021, 05:16:47 PM »
short course finds all knew kinds of issues over woods racing.  its fun.
Re: 571
« Reply #1172 on: June 27, 2021, 05:18:49 PM »
Right?
Successful tow truck to get broken bro into the box. That’s was a three man show but 571 was the star!
Re: 571
« Reply #1173 on: July 25, 2021, 12:53:46 PM »
Planning to grab Josh’s 37s from the xj as new to me tires for this.
Re: 571
« Reply #1174 on: September 10, 2021, 02:48:16 PM »
#4 plug was carboned up. Suspect sticky injector.
Still stumbles.
Want to check fuel pressure still. Does change if I close the return. But not fully fixed.
Re: 571
« Reply #1175 on: September 18, 2021, 07:53:48 PM »
Goes super lean at full enrichment romp-on-it.
Fuel pressure is good. High if anything.
So it’s absolutely just the tune that needs work.
Forgot I had this wide band sitting. Unsure if I have enough clearance for full suspension uptravel where I put the bung when I did the exhaust.
Video of gauges in a bit.
Re: 571
« Reply #1176 on: September 18, 2021, 08:06:33 PM »
Re: 571
« Reply #1177 on: September 26, 2021, 11:00:24 PM »
Considering whether it’s worth it to bring this Saturday, it will be untouched since last race and steering scared me once. I’m thinking not. Better to get some tune work done and probably change pump and maybe overall steering design
Re: 571
« Reply #1178 on: October 31, 2021, 10:59:31 AM »
Steering pump showed itself to be weak a couple times yesterday.
I should have aired down for rec wheeling. Idk why I didn’t think about it. Had to beat on it for some good achievements (shoot the moon) and had more than several denials (trail 5 hill climb, a couple lines on Crawl Daddy
Broke something in the front end on that last hard obstacle on crawl daddy. Suspect some missing ring gear teeth.
Thinking about a cross country trip and failure points and things that should live in the hauler:
Spare shafts
Wheel bearings
Brake lines
Calipers pads and retainers/ mounting hardware
Hyd lines
Alternator
Ps pump fluid and filter
Oil and filter
Gears and carriers and bearings and gear oil
Diff covers and spare bolts
Drive shafts & yokes & carrier bearing
Things it needs:
Radio programmed to frs channels
Radio antenna
Steering pump and resi
Front driveshaft something. CV or angles. Only good to 50-60mph
Engine tune - stalling, stumbling, exceedingly poor throttle response
Re: 571
« Reply #1179 on: January 21, 2024, 08:50:15 PM »
Brett was over today and noticed a couple critical issues on this while evaluating the fleet. Front housing cracked at ubolt cut, and rear ujoint protector nigh ripped off. Probably many stripped bolts holding the pinion carrier.
Re: 571
« Reply #1180 on: March 30, 2025, 07:44:25 PM »
another calendar year has passed
are you gona throw some time and parts at this guy this year?
do you have a PN from behemoth for the output you ordered? their website is shit stain and only thing i painfully found was this guy:
https://www.behemothdrivetrain.com/products/big-stubby-super-short-rear-output-shaft-for-np205?_pos=16&_sid=15399a7a7&_ss=r
Re: 571
« Reply #1181 on: March 30, 2025, 08:03:57 PM »
don't hold breath on throwing things at it this year. IDK. larger pile of money and a 4 wheel steer build seems like what would hold my interest best if I was going to?
no for sure part number because I didn't get any confirmation on my order. yeah that website is SHIT. damn.
compare what you linked to those pictures earlier in thread - linked one is stubby, mine is as long as stock.
I couldn't find a damn thing on his site either. Not sure if his production has gotten more reliable in the last 5 years?
Re: 571
« Reply #1182 on: March 30, 2025, 08:11:37 PM »
i was just wondering the cost.  i dont see any other options on the internet for a stock dimension replacement.
i fully support you in a rear steer 2 seat version based off my car haha.  i have another 2.2/4t45, harness and PCM /TCM sitting here on a pallet and will have another set of 42s in a couple weeks.
SD60s are still cheap.
 :o
Re: 571
« Reply #1183 on: October 16, 2025, 01:00:24 AM »
Battery is dead shot
Moved tonight. Noted odd bolt happening on the left front.
« Reply #1184 on: October 16, 2025, 07:37:43 AM »
