Author Topic: 571  (Read 264710 times)
Re: 571
« Reply #1110 on: September 13, 2018, 10:14:50 PM »
shit, I just parked it in.
I'll have to stash a jetta key for you. it's home.
Re: 571
« Reply #1111 on: September 13, 2018, 10:18:08 PM »
that would be great, thanks.  I should have remembered sooner and could have helped you rig swap.
Re: 571
« Reply #1112 on: September 16, 2018, 05:47:11 PM »
Didn’t fix itself. Reasonable suspicion that I have no spark, i think I’m catching a smell of fuel in the exhaust. Car clean, taking a moment and then pursuing with dry clothes. And especially shoes. Dry shoes.
Re: 571
« Reply #1113 on: September 17, 2018, 12:59:58 AM »
Blown ecu fuse.
Shameful.
No idea what caused it to blow. Was fine running for 20m after fuse replacement.
Lots of fans to fix (all 3 of them), broken stub shaft, and my favorite link bushing shot again. Along with a few other minor issues.
Re: 571
« Reply #1114 on: October 11, 2018, 08:41:02 PM »
Know what’s really hot? A wire that’s melted it’s insulation due to overload/undersize. Maybe don’t unplug by grabbing with bare fingers while under load.
Fucking dumbass.
Re: 571
« Reply #1115 on: March 22, 2019, 05:46:09 PM »
anyone want to help my laziness and pick out a torque converter I can just click a button on and have show up? Summit filters by stall speeds but the specs are not laid out at all once filtered and I click through on many of them. I was thinking something speced at 3200-3600. Hayes Twister, Boss Hog, Allstreet, and Summit brands all come up, from $200-$370, and only 2 of them bother to list a stall speed after clicking through.
I got annoyed and abandoned that set of tabs earlier this week.
I wonder if my year this year will be closer to smike's last – I'm not excited to race prep at all. I think I need a 1.5 car shop with a max jack...
Re: 571
« Reply #1116 on: March 22, 2019, 06:46:03 PM »
i went with a remanufactured TC at 2600-2800 and I thought it was good for the cam motor.  i dont feel it or hate it with the stock 5.3 back in.
yours is old school right and not an LS converter, you have the 10mm spacer kit on your flex plate to the old style TH350 still?
Re: 571
« Reply #1117 on: March 22, 2019, 07:59:55 PM »
Standard TH350, yes.
Re: 571
« Reply #1119 on: March 22, 2019, 08:17:00 PM »
in 2010 the car got this according to a gmail summit converter search on my account:
https://www.summitracing.com/parts/bmm-20400
Re: 571
« Reply #1120 on: March 22, 2019, 08:21:05 PM »
this is best summit option for the $$
https://www.summitracing.com/parts/sum-g2698
Re: 571
« Reply #1121 on: June 08, 2019, 12:42:42 PM »
Looking to make the center stack and tcase mounts removable. Otherwise tcase can’t come out without trans removal, and this will make trans removal much easier too.
What I consider the right way to do it is crazy expensive since I’ve got to break 8 tubes.
Time to booty fab, I guess.
https://www.trail-gear.com/chromoly-interlocking-tube-clamps.html
Re: 571
« Reply #1122 on: June 08, 2019, 01:20:32 PM »
i bet those things are great for aesthetic tubes that will never move.  in a car that is beat on and constantly moving, there is no way that something like that will work in more than 2 dimensions with out a porta ram for assembly....
Re: 571
« Reply #1123 on: June 08, 2019, 02:06:04 PM »
Not wrong. Multiple planes of tubes going on there too. I’ve got a plan. Plates cut. First tube cut and it didn’t spring at all. I’m _shocked_
Lunch break.
Re: 571
« Reply #1124 on: June 08, 2019, 02:09:02 PM »
did the skid get changed?  i thought my plan was pull the skid and the case would come out.  i cant remember.
