Author Topic: 1986 MJ "the keeper"  (Read 58689 times)
Re: 1986 MJ "the keeper"
« Reply #135 on: January 10, 2013, 12:09:10 PM »
o got it
ill try to meet you, a lot of fun stuff in the shop to look at right now :)
« Reply #136 on: January 11, 2013, 09:30:16 AM »
whats your day like today
« Reply #137 on: January 14, 2013, 12:24:04 PM »
how did this machine perform this weekend?
« Reply #138 on: January 15, 2013, 11:22:19 PM »
thing was humming along great this weekend...
runs and drives great.. need to swap out the hoses and O2 sensor..
noticed a slight noise in gear.. seems to be coming form the trans... unsure if it just started or??
always been looking for a AX5/231 anyway...   ;)
« Reply #139 on: January 22, 2013, 03:15:38 PM »
used 4.10 gearset, carrier and spiders in the mail....
new driver fender and door hinges arrived..
« Reply #140 on: January 29, 2013, 09:25:11 AM »
got the new gearset for this guy....
waiting to hear about body and paint before any more work is done...
« Reply #141 on: March 18, 2013, 10:53:04 AM »
possibly drop this guy off to button it up...
need to throw in the new gear set and possibly swap hinges on the front door if your feeling up to it...
« Reply #142 on: March 18, 2013, 11:31:34 AM »
gear set shouldnt be a problem- have the shim kit for it?  i think my Dana30 stuff is beyond gone.
whats the door hinge problem?  they usually suck and snap off
« Reply #143 on: March 18, 2013, 01:13:10 PM »
I have a timken rebuild kit i keep on the shelf in my garage.. should have everything..
wont the shims be reused from the old one?
I got a set of NOS door hinges.. they are sagging and I dont get a good seal...
caused me to tweak the front fender.. that I also have a new one for..
« Reply #144 on: March 18, 2013, 01:19:17 PM »
need a few shims to do it 95% of a 1000$ gear install in 15 minutes once tore down, or i can throw it in as is and it will be noisy and most likely fail pinion bearings down the road.
« Reply #145 on: March 18, 2013, 01:22:34 PM »
you know more than me... gears scare me..
it is in a truck that will only see 4wd if it gets stuck or I need to drive a pickup in the winter...
« Reply #146 on: March 18, 2013, 01:25:31 PM »
if you have the install kit throw it in- i will only use a few shims from it if needed and send it back.  i might have what i need.  i have been tearing down scrap axles and just keeping the parts on the shelf since Bill and I always need them it seems.
« Reply #147 on: March 18, 2013, 01:51:21 PM »
i dont care either way... rather do it correct once...
« Reply #148 on: March 27, 2013, 11:09:23 AM »
is the MJ outside?
« Reply #149 on: March 27, 2013, 11:17:57 AM »
yes
