Author Topic: 1986 MJ "the keeper"  (Read 67346 times)
Re: 1986 MJ "the keeper"
« Reply #120 on: January 07, 2013, 09:40:15 PM »
sway bar links are done
trans and engine mounts are done
rear wheel spacers red lock tited on
fronts need longer studs
looks sick, id leave it.
« Reply #121 on: January 08, 2013, 07:56:56 AM »
aside from being mathematically perfect I have a bit of rubbing when at full lock... perhaps the isolators fixed that?? I know the .375" spacers might not have cured it... but???
« Reply #122 on: January 08, 2013, 08:34:49 AM »
the rubbing is the inner side wall of the tires on the lower links.
you would need a lot less backspace to get away from that, or i could make the stops longer
« Reply #123 on: January 08, 2013, 08:36:48 AM »
how much less?  are we talking about full 1" spacers?
« Reply #124 on: January 08, 2013, 08:38:37 AM »
ohh.. and again.. not a right now deal... but whats a good R&P set to order for this guy and do I need a new carrier?
« Reply #125 on: January 08, 2013, 08:44:38 AM »
carier break is 3.73, so if it is numerically less than 3.73 you will need a carrier and install kit
or get a used 4.10 axle
« Reply #126 on: January 08, 2013, 09:07:12 AM »
i assume this hog has 3.55s now?
i have a 3.73+ carrier if needed. in my "D30 Fix" box. no use to me now  :D
« Reply #127 on: January 08, 2013, 09:14:41 AM »
used stuff is way faster to put in with some thought.
« Reply #128 on: January 08, 2013, 09:35:11 AM »
been looking... but for the amount of time its in 4wd i figued the re gear would be faster and cheaper...
I sunk tons of parts into that front end recently.. ball joints, u joinds, hubs, brakes etc...
I already have a Timken Master kit... just would need carrier and gears...
dunno.. still looking for an easy swap option as well..
« Last Edit: January 08, 2013, 09:47:54 AM by rejeep »
« Reply #129 on: January 08, 2013, 11:41:14 AM »
i just ment used axle to pull the gear set out of, not swap the axle...
much easier to tweak a pattern in a different housing than start from fresh with all new parts.
Also, if you want new studs pressed in for the spacers, we should do that at the same time.
« Reply #130 on: January 08, 2013, 01:02:13 PM »
got it... so buy a used gear carrier and gear set...
« Reply #131 on: January 10, 2013, 11:43:04 AM »
this guy can get picked up right?
Need to throw away some counter tops this weekend...
Might swap the MJ for the XJ so I dont have to get a ride and perhaps a new sensor for the FI and winch install if you dont mind easy stuff..
I can bring down with your parts and fluids..
« Reply #132 on: January 10, 2013, 12:01:18 PM »
sure.  you have an extra key or no?
« Reply #133 on: January 10, 2013, 12:02:50 PM »
or just shoot me a txt i can meet.  going to eat now
« Reply #134 on: January 10, 2013, 12:03:44 PM »
no ... but wont be till tomorrow... so we can stash it...
