Author Topic: Willys MB build  (Read 195960 times)
Re: Willys MB build
« Reply #690 on: December 16, 2016, 12:54:59 PM »
Field Inv package returned yesterday requesting MCO (Manufacturer's Certificate of Origin) or receipt for chassis. Understandable if the two departments aren't communicating as this package would seem quite incomplete without the other.  Explanation letter and additional process photos forwarded.
Re: Willys MB build
« Reply #691 on: January 03, 2017, 04:50:56 PM »
Email received re: examination appointment. Scheduled for 1/17/2017...
Re: Willys MB build
« Reply #692 on: January 04, 2017, 12:03:52 PM »
Good luck.
Re: Willys MB build
« Reply #693 on: January 21, 2017, 10:09:33 AM »
While I'm waiting on the DMV examiner...
Bought a porta-ram and un-tweeked the radiator hoop and A-pillar hoop as much as I could. Refabbed the radiator and grille mounts.
Added spreader bars
Also started on the fuel cell
Not sure how far to go with internal baffling. Figured two like the one pictured, for baffling and structure. Will be running factory style GM internal pump.
Re: Willys MB build
« Reply #694 on: January 21, 2017, 05:33:43 PM »
If you're not doing a "clunk" or walboro type mats, I'd suggest a cup of sorts that your return runs into to help with using the last of the tank. Some overlapping spirals or angles to catch the slosh and allow it to be picked up when at an angle.
Two baffles like that to break it into thirds seem like plenty for half-tank slosh and structure. Looks good.
Re: Willys MB build
« Reply #695 on: January 22, 2017, 11:14:50 AM »
GM fuel pump has built-in reservoir cup. Part store availability. Not expensive. Fuel gauge potential.
Dorman 2630370
Re: Willys MB build
« Reply #696 on: January 22, 2017, 11:40:12 AM »
dmv pass yet?
Re: Willys MB build
« Reply #697 on: January 22, 2017, 04:16:16 PM »
Will that survive getting banged around?
Re: Willys MB build
« Reply #698 on: January 22, 2017, 04:27:11 PM »
DMV delayed until end of month.
No idea if it'll survive the abuse. It is spring-loaded so it shouldn't move much. I guess I'll find out.
Re: Willys MB build
« Reply #699 on: January 22, 2017, 09:56:19 PM »
factory tanks have some reliefs in the bottom of the tank that those sort of lock into. if you can do something similar that would register with the bottom of the pump it ought to last juuuuust fine.
Re: Willys MB build
« Reply #700 on: January 22, 2017, 10:04:52 PM »
I'll tack a ring or nut on the bottom for a couple of the "feet".
Re: Willys MB build
« Reply #701 on: February 03, 2017, 08:30:59 AM »
Re: Willys MB build
« Reply #702 on: February 03, 2017, 08:32:50 AM »
It now has an official VIN number, title process continuing...
Re: Willys MB build
« Reply #703 on: February 03, 2017, 09:25:09 AM »
That probably deserves a party.
And maybe a writeup on the whole process ;)
Re: Willys MB build
« Reply #704 on: February 03, 2017, 09:35:50 AM »
awesome!
