Author Topic: Willys MB build  (Read 195946 times)
Re: Willys MB build
« Reply #660 on: October 18, 2016, 11:12:16 AM »
needs 39s   jump one those, could have picked them up this weekend bah!
Re: Willys MB build
« Reply #661 on: November 01, 2016, 08:51:55 PM »
are you using your tablet as like a low buck lowrance gps as well as the guages?
Re: Willys MB build
« Reply #662 on: November 01, 2016, 08:57:11 PM »
Yes, Android-based Torque app and Maplets.
Re: Willys MB build
« Reply #663 on: November 01, 2016, 09:08:14 PM »
Finally got the second t-case shifter vetted and installed. Required a little trans pan trimming but not bad. It'll be nice to have HI range available. Also, low range front dig now possible.
Re: Willys MB build
« Reply #664 on: November 01, 2016, 09:11:18 PM »
whats your fuel cell size and do you have head lights?  just wondering.
Re: Willys MB build
« Reply #665 on: November 01, 2016, 09:12:49 PM »
do you need a data package to run the maplets or do you just use a external gps antenna
Re: Willys MB build
« Reply #666 on: November 01, 2016, 09:16:12 PM »
While at Rausch last weekend, the shift rail cap popped off and drained nearly all of my t-case on Shoot the Moon. I am now hypothesizing that it occurred because of hydraulic pressure. The caps fill with fluid and then when shifting, the fluid cannot exit the cap fast enough and it gets pushed out. While it may not pop off on the first shift, it likely loosened it to the point that another shift or hard bump may eject the cap. This wouldn't occur if the Dana 300 wasn't upside down because no fluid would settle or drain into the caps.
Here is my quick and dirty solution
Re: Willys MB build
« Reply #667 on: November 01, 2016, 09:17:58 PM »
It works without any external antenna or data.
Re: Willys MB build
« Reply #668 on: November 01, 2016, 10:21:03 PM »
Fuel cell is 12 gal, working on lights tomorrow
Re: Willys MB build
« Reply #669 on: November 02, 2016, 08:27:23 AM »
i have a couple LED bars and cubes kicking around if you need anything
Re: Willys MB build
« Reply #670 on: November 02, 2016, 06:03:23 PM »
I don't like wiring  :-\
5+ hours and it's not done or done right...
Re: Willys MB build
« Reply #671 on: November 02, 2016, 06:08:00 PM »
On a better note, HI range is wonderful! Can't wait to see what it's like on the road at 55mph. It'll need sway bars or a bit of shock adjustment though.
Re: Willys MB build
« Reply #672 on: November 02, 2016, 09:15:19 PM »
Bring it by mike’s tomorrow, I’ll make it work.
Or burn it trying.
Re: Willys MB build
« Reply #673 on: November 02, 2016, 09:22:04 PM »
I'm good at wiring. I don't think I'll get to help you! Haha
 I offered to help you with engine wiring and you declined!
Re: Willys MB build
« Reply #674 on: November 02, 2016, 10:01:15 PM »
Thanks guys! I do appreciate the offers.
It'll be "done" by loading time tomorrow evening. It really isn't that bad and I'm just whining. Besides, we all have to do things we don't enjoy every now and then...
