Author Topic: Willys MB build  (Read 195954 times)
Re: Willys MB build
« Reply #720 on: March 24, 2017, 09:31:26 PM »
nice work on the wiring Mark.
Re: Willys MB build
« Reply #722 on: March 27, 2017, 07:05:06 PM »
Ooooo, kinda dig that!
Re: Willys MB build
« Reply #723 on: April 11, 2017, 04:34:06 PM »
New accessory drive routing is a failure.  >:(
Belt flaps badly between crank pulley and alternator under any current load. I can quiet it with added pressure on the tensioner but not adequately.
Attempt #2 = Goatbuilt low-pro alternator mount and tensioner, enroute.
Re: Willys MB build
« Reply #724 on: April 11, 2017, 05:24:51 PM »
sounds like too long a belt, then? or is the tensioner just not at the right angle to do what it needs to do?
hopefully the goat will get you taken care of!
Re: Willys MB build
« Reply #725 on: April 11, 2017, 06:42:14 PM »
Tensioner currently positioned to provide maximum travel and leverage, belt correct length to put tensioner in the "zone".
My theory is that the current placement puts the tensioner in a location where it cannot react properly, between accessories on the tension side instead of the slack side. I think it has to be right after the crank pulley no matter where your accessories are placed.
Re: Willys MB build
« Reply #726 on: April 12, 2017, 12:56:47 AM »
Can't pull through the tensioner.  It's got the be in the "slack" area that the cranks is pushing the belt to, yup
Re: Willys MB build
« Reply #727 on: April 12, 2017, 05:32:35 PM »
Goatbuilt bracket solved the issue.
I also routed the belt differently. The current belt loops around the alternator, under the water pump, around the power steering, and back to the crank - no idlers in the system, just the tensioner. Simple and "short".
Re: Willys MB build
« Reply #728 on: April 13, 2017, 11:13:05 PM »
Cut some plywood to cover and insulate the floor and protect the fuel cell.
Also mounted the nitrogen bottle again.
Mounted a permanent first aid kit.
Harry found me a set of red label BFG Krawlers in Texas. Fastenal shipping FTW.
Mounted up on KMCs. Nice to have tread!
First time out of the shop since Nov.
Re: Willys MB build
« Reply #729 on: April 15, 2017, 01:58:23 AM »
you ready for RC/AOAA?
Re: Willys MB build
« Reply #730 on: April 15, 2017, 10:04:12 AM »
I believe so.   ;)
Re: Willys MB build
« Reply #731 on: May 08, 2017, 06:28:40 PM »
Even though it was raining at RC this weekend, the improvements made over the winter performed as well as expected. The tires worked great.
Time to work on lighting.
Can't wait for the next trip! Field & Forest, look out!
Re: Willys MB build
« Reply #732 on: June 14, 2017, 11:29:14 AM »
Another hurdle in the road-legal process...
Ins agent is having a hard time finding someone to insure a custom-built body/chassis?
Re: Willys MB build
« Reply #733 on: June 14, 2017, 01:23:29 PM »
i sent an email to the guy here that has one that has been though the custom process asking his insurance.
wnyjpgy
Re: Willys MB build
« Reply #734 on: June 14, 2017, 01:59:01 PM »
I guy I work with built a "Locost" basically a homebuilt lotus 7, had to go though the same process as you.
He insured his as a partial use vehicle through Haggarty, he also said Grundy would have insured it.
