Author Topic: Willys MB build  (Read 195981 times)
Re: Willys MB build
« Reply #705 on: February 03, 2017, 12:13:31 PM »
That must be a relief...
Re: Willys MB build
« Reply #706 on: February 03, 2017, 02:36:43 PM »
I wasn't really worried about this part but still relieved that it is completed and the process is continuing.
Quick and painless 5 min exam. Wrote down the engine serial number, signed the form, and attached the sticker. Wasn't concerned with trans or t-case or any other parts since it was obviously all custom.
Forwarded a copy of the form to the Safety and Emissions department and now wait for them to issue a "Notice of Registration Acceptability". Then I can take a bunch of paperwork to the local DMV and apply for an official title.
Instructions for Registering a Homemade Vehicle
At some point, I will consolidate my experience.
Re: Willys MB build
« Reply #707 on: February 03, 2017, 07:48:42 PM »
Great news
Re: Willys MB build
« Reply #708 on: February 05, 2017, 03:38:55 PM »
What happens if you swap engines in the future?
Re: Willys MB build
« Reply #709 on: February 05, 2017, 04:05:40 PM »
Same as if I swapped any other engine in a pre-OBD2 vehicle - nothing.
Re: Willys MB build
« Reply #710 on: February 07, 2017, 10:00:34 PM »
I wondered because of the 'wrote engine serial' comment.
Re: Willys MB build
« Reply #711 on: February 07, 2017, 10:06:00 PM »
Mostly to check for stolen parts.
Re: Willys MB build
« Reply #712 on: February 13, 2017, 04:58:16 PM »
Fuel cell 99% finished.
Used some HF tread strips on the bottom to space it up off the floor
Needs a vent tube and some nice bolts/nuts
Re: Willys MB build
« Reply #713 on: February 13, 2017, 05:23:53 PM »
Also received my official "Notice of Registration Acceptability" letter. Only step left before trip to DMV for plates is the local safety inspection. That's going to wait until wheelin' season.
Now on to finishing...
Re: Willys MB build
« Reply #714 on: February 13, 2017, 05:56:24 PM »
Awesome!
Re: Willys MB build
« Reply #715 on: February 13, 2017, 10:25:50 PM »
nice mark!  double check the fine print that you have more than 30 days
Re: Willys MB build
« Reply #716 on: February 13, 2017, 10:52:32 PM »
No fine print and no indication of time limit.
Re: Willys MB build
« Reply #717 on: February 20, 2017, 07:16:23 PM »
Upgrading my engine fuse/relay panel
Old DIY basic hack
New unit with fan relays
Also ripping into the harness to cull some unneeded
trans wiring and relocate ECM inside/under the cowl
Re: Willys MB build
« Reply #718 on: February 21, 2017, 12:07:23 PM »
Looks good, want to come do mine..... ;)
Re: Willys MB build
« Reply #719 on: March 24, 2017, 01:13:53 PM »
Engine harness finally complete.
ECM, TCM, and fuse/relay block mounted to cowl
Also got accessory drive ironed out in prep for LS6 intake
2010 Camaro water pump
ICT Billet LS3 alternator mount
2000 Camaro tensioner, custom bracket
« Last Edit: March 24, 2017, 01:18:22 PM by Wingman »
