Author Topic: Willys MB build  (Read 196270 times)
Re: Willys MB build
« Reply #225 on: June 04, 2014, 09:41:47 PM »
I always try to weld uphill for the exact same reason. Both penetration and helping keep the puddle clean instead of overrunning imperfections.
[soap box]
that sounds like the internets talking ::)
I can lay the same bead in any position, flat / up hill / down hill / upside down.
I think up hill may work better (slower puddle) if your welder is is not up to the task.
When I weld down hill I just crank up the welder and hammer down.
I guess what im saying Mark, is dont be afraid of down hill welding,  it has its place..
I give you props for posting your work.  Most never fab, much less post their work.
Keep at it.  Im loving it.
« Last Edit: June 04, 2014, 09:46:20 PM by gif »
Re: Willys MB build
« Reply #226 on: June 05, 2014, 12:11:22 AM »
im with gif
if you have a bad weld in a certain direction, you need more practice with your machine :)
Re: Willys MB build
« Reply #227 on: June 05, 2014, 08:28:17 AM »
I've got the welder set at the upper range for the material so it should be plenty hot.  Penetration looks good on these.  First beads in a month plus.  Practice, practice, practice!
I fully expect something on this build to come apart on it's maiden voyage.  I envision pulling it out of the trailer, bumping the first rock, and it collapsing around me, leaving me holding the steering wheel with a sad look on my face.
So keep at me with the criticism!  Constructive or otherwise...  ;D
Re: Willys MB build
« Reply #228 on: June 05, 2014, 12:44:34 PM »
Practice is definitely key.
I always find myself needing to brush off the cobwebs after not welding for a while because of a Month Long Road Trip!
Looking Good!
Re: Willys MB build
« Reply #229 on: June 07, 2014, 09:31:03 AM »
98 lbs of rear axle housing shipped yesterday.  Finally.
Re: Willys MB build
« Reply #230 on: June 07, 2014, 05:17:39 PM »
Installed the new AA input gear into the t-case, temporarily bolted on the adapters, and test-fit the combination.  Looks like I'll be playing with some custom clocking a bit to see what will give me the best-scenario clearance.  The adapter came with two choices and the "flattest" one is still about 1.5" below belly line and tight in every way.  Trans pan and likely some of the case will need clearancing.
SlvrJK
  • Full Member
Re: Willys MB build
« Reply #231 on: June 07, 2014, 11:42:52 PM »
Sweet
Re: Willys MB build
« Reply #232 on: June 08, 2014, 09:59:57 AM »
What about a clocking ring?
Does the adapter use the stock 300 input ? Or does it replace it?
The A A clocking ring comes with a longer input and allows multiple mounting  positions.
Re: Willys MB build
« Reply #233 on: June 08, 2014, 10:04:27 AM »
Input replaced with GM 27 spline.  Shouldn't be too difficult to drill 6 new holes in the aluminum adapter.
Re: Willys MB build
« Reply #234 on: June 09, 2014, 01:54:47 PM »
Playing with flipping the D300.  Lots more clearance on the driver's side for the driveshaft but the shifter mechanism is into the trans pan.  A little research seems to say that just flipping it without moving the shifter mech results in consistent leaks.  There are a few kits that delete the shift rails at the stock location and add a shifter assembly on "top" of the pan.  Stak makes a full replacement aluminum case that moves everything as well as reducing weight.  It's pretty too.  Still less money than an Atlas.
Opinions?  Other than go-buy-an-Atlas...
Callelle
Re: Willys MB build
« Reply #235 on: June 09, 2014, 02:48:27 PM »
Go steal an steal an atlas.
Sent from my SCH-I535 using Tapatalk
Re: Willys MB build
« Reply #236 on: June 09, 2014, 02:56:30 PM »
atlas is aluminum
Re: Willys MB build
« Reply #237 on: June 09, 2014, 02:57:08 PM »
NP231 and DONE
Re: Willys MB build
« Reply #238 on: June 09, 2014, 03:18:46 PM »
Can you actually just take everything out of a 300 and put it in that Stak housing? It relocates the shifters to the top of the case without adding any extra parts?
Down East Offroad seems to make a kit to relocate shifters to the top, but it looks like I'd have to give up a ton of floor to make that work. Stak housing looks pretty close to D20 in size. And it is pretty.
Having a hard time seeing how $450 into a D20 with no option for stronger front output is a good idea... I'll be paying close attention to what direction you go in here!
/hijack
Re: Willys MB build
« Reply #239 on: June 09, 2014, 03:34:52 PM »
205's still looking good!
