Author Topic: Willys MB build  (Read 195981 times)
Re: Willys MB build
« Reply #255 on: June 18, 2014, 05:36:10 PM »
Boy that's short. What's your suspension travel goal? As in what shocks do you plan to run and how bad is that going to be on driveline angles at droop
Re: Willys MB build
« Reply #256 on: June 18, 2014, 05:55:41 PM »
i see limit straps in your future
Re: Willys MB build
« Reply #257 on: June 18, 2014, 06:50:02 PM »
Nearly 2 inches longer than a TJ rear drive shaft.  I'm thinking about 4" compression and 6-8" droop.  We'll see.  Limit straps already on the radar.
Re: Willys MB build
« Reply #258 on: June 18, 2014, 08:28:52 PM »
Just measured mine at 16 1/4. You doing CV?
Re: Willys MB build
« Reply #259 on: June 18, 2014, 08:53:02 PM »
DC?  Absolutely!
Re: Willys MB build
« Reply #260 on: June 19, 2014, 04:46:16 PM »
More Ruffstuff today.  Pinion guard, axle seals, clevis mounts, brake line brackets...
Fully welded the control arm mounts on the axle housing and spray-bombed.
Lower welds look OK.
Upper welds not great.  Hopefully "gorilla" quality.
And installed the axle seals...
Re: Willys MB build
« Reply #261 on: June 19, 2014, 04:56:50 PM »
It appears you're using that green etching primer? That stuff is awesome.
Re: Willys MB build
« Reply #262 on: June 19, 2014, 05:09:34 PM »
Nah, just green camo
Re: Willys MB build
« Reply #263 on: June 19, 2014, 05:11:25 PM »
Channeling your inner 315. I approve.
Re: Willys MB build
« Reply #264 on: June 19, 2014, 05:13:37 PM »
 :o
Re: Willys MB build
« Reply #265 on: June 20, 2014, 05:11:56 PM »
Links!
...and some hand-crafted machining.
Re: Willys MB build
« Reply #266 on: June 20, 2014, 06:29:19 PM »
Flipped Her Eh?
Re: Willys MB build
« Reply #267 on: June 24, 2014, 12:33:04 PM »
Re: Willys MB build
« Reply #268 on: June 24, 2014, 12:51:05 PM »
oh, that's NICE.
Re: Willys MB build
« Reply #269 on: June 24, 2014, 01:44:04 PM »
sure is
