Author Topic: Willys MB build  (Read 195980 times)
Re: Willys MB build
« Reply #285 on: July 18, 2014, 08:34:06 AM »
did you cut the tubes, or cut the C's to get them off?
ill take the housing off your hands if its full length
Re: Willys MB build
« Reply #286 on: July 18, 2014, 09:18:21 AM »
I cut the tubes.  The Cs have to be opened up to 3.25" anyway and I was getting frustrated swinging the BFH.  Burned through 3 porta-band blades on one side, plasma'd the other.  Hence "paperweight" status...
Re: Willys MB build
« Reply #287 on: July 18, 2014, 09:41:01 AM »
Brake conversion weight reduction calculated with quality digital calibrated bathroom scale.  21# per side of a D60 (brackets, rotors, calipers, no pads).  34# vs 55#.
Re: Willys MB build
« Reply #288 on: July 18, 2014, 09:46:05 AM »
42# is pretty good
Re: Willys MB build
« Reply #289 on: July 18, 2014, 09:36:50 PM »
Temporary F9 prepped and ready for cutting to length.
Not 100% sure about the long center section being too long for short side.  Bah!
Re: Willys MB build
« Reply #290 on: July 18, 2014, 11:12:33 PM »
I was worried about the opposite... Does leaving one side (or the longer of the two if its offset a little) leave you enough width to get your WMS where you want it? I'm guessing it does if you're moving forward with it this way
Re: Willys MB build
« Reply #291 on: July 19, 2014, 07:50:25 AM »
Just.  The neck-down bearing portion (about 2") gets chopped.  That's all.  So I guess the long center section really is no issue.
Re: Willys MB build
« Reply #292 on: July 26, 2014, 05:19:11 PM »
Rollers mounted on rear, front housing ends cut to approx width, leaf springs removed, housing slung.  ~28" lower link length (90" WB).  Things get a little tight near the oil pan...
Re: Willys MB build
« Reply #293 on: July 28, 2014, 09:04:58 AM »
Re: Willys MB build
« Reply #294 on: July 28, 2014, 09:52:02 AM »
Probably.  Could have been wheelin' for the rest of the season too.
Besides, wanted to do things "my way"...
Far too deep into the Rubi account now.  Meh.
Re: Willys MB build
« Reply #296 on: July 30, 2014, 11:03:59 AM »
another inspiration!
Quote from: bbaxter51;26985185
Finished out the side skins so they match the hood perfectly on the Super Willys.
Re: Willys MB build
« Reply #297 on: July 30, 2014, 11:11:45 AM »
I like
I like
Re: Willys MB build
« Reply #298 on: August 16, 2014, 09:42:32 PM »
Re: Willys MB build
« Reply #299 on: August 17, 2014, 09:37:15 AM »
Ordered front housing and REID inner Cs.
Thanks Erik!
