Author Topic: Willys MB build  (Read 195960 times)
Re: Willys MB build
« Reply #210 on: April 29, 2014, 12:40:55 PM »
You've been busy while we were on Vacation.
Re: Willys MB build
« Reply #211 on: May 01, 2014, 05:24:17 PM »
Finished up door tubes, roof stringers, and rear struts.  Even got my rattle can out.
SlvrJK
  • Full Member
Re: Willys MB build
« Reply #212 on: May 01, 2014, 05:27:51 PM »
Nice work Mark
Re: Willys MB build
« Reply #213 on: May 02, 2014, 03:22:45 PM »
Special delivery from Arie arrived today!  AA trans to t-case adapter and D60 hub assemblies.  Hubs even had bearing races already pressed in, too.  Bearings in stock locally, yea!
Re: Willys MB build
« Reply #214 on: May 02, 2014, 03:23:58 PM »
thats crazy races too!
Re: Willys MB build
« Reply #215 on: May 02, 2014, 03:29:33 PM »
Mark..
What bearings did you get?
Parts master bearings are ok and all.. But for a wheeler with your power to weight ratio I would have gone national or timken.
All delco OE parts should come preassembled..  Glad to see they are still doing it
Re: Willys MB build
« Reply #216 on: May 02, 2014, 03:39:55 PM »
PMA38 outer, PM387AS inner
I didn't specify, my fault.  I would have had you order them but I wasn't sure if they'd be loaded hubs.  We can worry about it later.
Re: Willys MB build
« Reply #217 on: June 04, 2014, 04:51:08 PM »
Got back to work the last couple days.  Engine mounts done.
First attempt was tube connected to the bushing sleeve resulting in a solid mount with no bushing engagement (duh) but didn't ruin anything that I needed to finished.  Cut it off and ground what I could hence the ugliness around the bushing sleeve.
Learned something new today = Weld downhill for better control of the puddle.  Did a couple of ugly droopy beads today resulting in additional passes to clean them up.  :-[  Other side looks far better.
There will be a removable crossbar connecting each once I borrow a bender again.
Re: Willys MB build
« Reply #218 on: June 04, 2014, 04:57:07 PM »
how is your frame that wide, you are gona be rubbin!
 :o
Re: Willys MB build
« Reply #219 on: June 04, 2014, 05:00:17 PM »
34" outside.  Should be fine.
Re: Willys MB build
« Reply #220 on: June 04, 2014, 05:01:34 PM »
good 5-6" wider than any of the front engine cars i have done as i suspected
Re: Willys MB build
« Reply #221 on: June 04, 2014, 05:03:21 PM »
Wanted it wide enough for exhaust manifolds and spring perches.  I believe it to be only a couple inches wider than a TJ.
Re: Willys MB build
« Reply #222 on: June 04, 2014, 07:16:29 PM »
Welders say always weld up hill. Otherwise the weld moves faster than the heat and you have reduced penetration.
Source: DOT licensed professional bridge welder.
Re: Willys MB build
« Reply #223 on: June 04, 2014, 08:26:06 PM »
I have NEVER had an issue with downhill.
This project i did has a ton of downhill welding.
http://www.pirate4x4.com/forum/tow-rigs-trailers/879399-gooseneck-trailer-conversion-build.html
Re: Willys MB build
« Reply #224 on: June 04, 2014, 09:09:14 PM »
I always try to weld uphill for the exact same reason. Both penetration and helping keep the puddle clean instead of overrunning imperfections.
