Author Topic: rescuing an old friend  (Read 114479 times)
Re: rescuing an old friend
« Reply #405 on: September 21, 2016, 11:48:21 PM »
man you are pulling a chip!  one problem avoided with tearing into 14 non problems to disable the jeep!
« Reply #406 on: September 22, 2016, 07:36:30 AM »
all issues are related to the same root problem..
shit doesn't run correctly.
- had to pull glovebox for engine CPU
- daisy chain of hacks into a column Crank/Run wire...  need dedicated circuits, and some things can go away for good..
- gauge pod didn't want to register temp.. thats kinda  a problem with a fresh motor/head
Jeep still runs and drives and its not locked in a building somewhere...
you gave me a nice (and much appreciated) head start on this. I would have wandered down the path of coating manifolds, painting stuff, engine compartment cleanup, etc.   that would have been Chip worthy..
« Reply #407 on: September 22, 2016, 08:34:37 AM »
haha
it will live again.  fun jeep.
just poking you along!  :)
« Reply #408 on: September 22, 2016, 10:36:03 AM »
I'm not getting enough fuel at idle.
Howell sending me a new "stock" prom with a touch richer mixture at cold idle
Troy says cam chips are normally leaner and that could be the issue I am having.
If this chip and traditional engine tuning doesn't resolve there is something going on with pump in tank.
« Reply #409 on: September 22, 2016, 09:31:37 PM »
Coolant temp sender swapped out for OE
Valve cover removed for re seal.
« Reply #410 on: September 25, 2016, 08:56:20 PM »
Some weekend work while waiting for new prom...
- Valve cover resealed
- gauge pod back together
- fuel lines will need to be rerouted
Temp gauge still inoperable... New sending unit tests ok, ordered a new gauge
Ran engine to operating temp and no leak from back of valve cover..
Not happy with where fuel line is.  I feel it's getting cinched between body and frame.
Pulled it ontop of frame in wheel well to have unrestricted flow..
Back of the Land Rover has become YJ workstation.
« Reply #411 on: September 26, 2016, 06:18:21 PM »
New chip and a new set of problems..
engine runs great... have smoke.. something is fucked..
« Reply #412 on: September 26, 2016, 06:25:39 PM »
like mosquito clearing smoke..  I'm so over this shit
OBD has coolant temp right where it should be, good oil pressure.. haven pulled plugs yet
« Reply #413 on: September 27, 2016, 01:26:07 AM »
stop guessing and get a laptop on this thing
« Reply #414 on: September 27, 2016, 07:26:19 AM »
unless a laptop can tell me whats going on inside the motor its going to be useless...
Fuel delivery is running best it has in years..
white smoke coming from tailpipe and breathers is telling me this thing is fucked.
« Reply #415 on: September 27, 2016, 11:01:35 AM »
live data will show very quickly what is unhappy.  still sounds like fuel delivery issues.
« Reply #416 on: October 07, 2016, 09:09:17 AM »
spotted on FB today!
« Reply #417 on: October 07, 2016, 12:54:38 PM »
??? Where?
I'm not on the book
Dropped at Scottys for them to play with
Seems there might be an external oil leak from back of head.
Shop might have missed crack or bad head gasket.  Evaluating more this week.
« Reply #418 on: October 07, 2016, 03:39:53 PM »
looked like starbucks parking lot across the street
« Reply #419 on: October 07, 2016, 03:59:54 PM »
Yup that scottys.  But who's page??  I don't understand how that works
