Author Topic: rescuing an old friend  (Read 114332 times)
« Reply #30 on: February 09, 2012, 05:24:33 PM »
the little one is really the bees knees...
this one is just slightly used already...
« Reply #31 on: February 10, 2012, 10:12:31 AM »
That is only 2" of wheel well gap! Topsy turvy is this hogs new name!
so I was thinking..
would I be better off ditching the body lift all together...
the new fenders will give me greater wheel openings and I’ve decided to not go larger than 35"s on this truck with current axles and suspension...
thoughts?
How to throw Money at a YJ...
« Reply #32 on: February 10, 2012, 10:15:42 AM »
Ditch it!
« Reply #33 on: February 10, 2012, 10:19:00 AM »
« Reply #34 on: February 10, 2012, 01:09:28 PM »
Only reason not to ditch...  If you are installing a tummy tuck.  It may make the fitment easier.
« Reply #35 on: February 10, 2012, 01:43:13 PM »
I am ordering a set of poly body mounts...
since they are both coming from amazon I can return them even after a potential test fit...
im siding with the ditch it
« Reply #36 on: February 10, 2012, 02:49:23 PM »
no stock height body mount kit comes with all the parts...
sleeve, washer, bolts, etc... >:(
« Reply #37 on: February 10, 2012, 03:02:06 PM »
cant believe it...
I just grabbed a set of stock rubber mounts that come with the mushroom washer and sleeve...
still have to grab a box of bolts if I go this way..
« Reply #38 on: February 10, 2012, 03:05:20 PM »
m4wd is a fully stocked hardware shop with way better locking hardware than the zink under sized junk any body kit comes with :)
« Reply #39 on: February 10, 2012, 03:08:10 PM »
so is the warehouse.... ;)
just irks me when they dont include hardware... like they expect you to re use any of the old shit anyway.
« Reply #40 on: February 13, 2012, 03:43:43 PM »
Well I didnt kill myself getting the jeep off the trailer
Rear axle out and off to SVE for ARB install..
Rear inner fenders and flares removed for TnT corner install...
kinda surprised at the lack of rust and rot.. a little scale and flake but not bad for close to a  25 year old vehicle..
everything unbolted even.. no cutting or cursing..
not going to go crazy with it.. just some sanding and POR for good measure..
« Reply #41 on: February 13, 2012, 03:45:38 PM »
you just did like 7 years of chip work right there, not bad.
« Reply #42 on: February 13, 2012, 04:24:15 PM »
yeah all from 12:30-2:30
and that after busting a Hyd line on the forklift and band aiding it together... because dont you know.. I dont have a floor jack up there and my engine hoist is on perm loan...
I got some M4wd speed and efficency when I need it..
« Reply #43 on: February 14, 2012, 10:15:58 AM »
I think I might have a couple hours in my hands tomorrow...
Might start clearing off the front fenders and possibly removal...
Made some mistakes with the rover painting before fitting...
not going to go through that again here..
« Reply #44 on: February 15, 2012, 11:52:52 AM »
stripped and got the front fenders off this morning...
awesome to work on something thats not rotted and everything just unbolts...
took about 90 min to remove all the acc. from the inner fenders and unbold the wings...
did some test fitting of the new front fenders and we have an issue..
the A to Z fab sliders extend way to far.. going to have to cut them down..
I want to see if I can use the bottom portion of the slider and just cut the horizontal section with a grinder or sawzall while still on the vehicle..  I have a feeling I will just be cutting off the complete excess flush with the body tub.
