Author Topic: rescuing an old friend  (Read 114645 times)
« Reply #345 on: July 26, 2013, 05:18:19 PM »
yeah I got a red dot on the control...
unsure
« Reply #346 on: July 27, 2013, 05:43:43 PM »
brake control question....
I have a delay unit.. not inertia...
when I push down on the brake there is a red dot..
CURT manual says thats what should be without a trailer hookup.. as it currently is..  can somebody confirm..
need to grab trailer tomorrow and double check
« Reply #347 on: July 28, 2013, 10:42:21 AM »
its always a ground issue with a trailer...
what are the odds.... both brake ground wires torn out of there eyelet crimps...
who knows might have been driving around with only one brake for god knows how long.
« Reply #348 on: July 28, 2013, 06:28:35 PM »
It's always the ground on a trailer!
« Reply #349 on: June 04, 2014, 10:20:48 AM »
Jeep is running like a raped ape with 100 octane and smikes fixes last year..
« Reply #350 on: June 18, 2014, 09:12:08 AM »
need to run some ATF and Techron in this guy...
noisy lifter starting to bother me....   I think its lazy
still running like a champ.. just sounds like a sewing machine....
Smike, any chance there could be a pinhole exhaust leak from the front pipe we did last year?
« Reply #351 on: June 18, 2014, 11:10:56 AM »
no chance with a bench welded exhaust
please do not run ATF through that motor
« Reply #352 on: June 18, 2014, 12:44:50 PM »
explain...   people swear by it
« Reply #353 on: June 18, 2014, 12:46:31 PM »
I have never heard of running atf  , what is it supposed to do?
« Reply #354 on: June 18, 2014, 12:51:09 PM »
my educated guess is ATF has a high level of detergents
you cant clean a motor back in to spec
its a 258, change the oil with some 10/30 and turn the radio up
« Reply #355 on: June 18, 2014, 12:54:28 PM »
1 qt in the motor oil.. run for 15 min and oil change...
the relative thinness of the fluid will help pump a lazy lifter back up....
theory
this too....
with all my vac leaks, timing issues, 100 octane fuel there could be some significant build up around the valves already...  could be causing a sticky valve or lifter..
I actually went to advance today... we don't carry techron, advance had buy 1 get 1 for a dollar...
« Last Edit: June 18, 2014, 12:56:10 PM by rejeep »
« Reply #356 on: June 18, 2014, 12:55:03 PM »
Old Jeep thing?  The ATF does contain more detergents and in theory will clean the sludge out.  Haven't heard of it being used on anything newer than 1970...
One quart ATF and the rest regular motor oil.
I wouldn't do it with anything that I own currently.
« Reply #357 on: June 18, 2014, 12:57:17 PM »
258 is a 1964 technology engine....
« Reply #358 on: June 18, 2014, 12:58:27 PM »
I dunno.. going to run a bottle of techron in the reminder of my tank..
I might get ballsy after that
« Reply #359 on: June 18, 2014, 01:00:08 PM »
I'm thinking it wouldn't hurt anything if run for such a short period.  Start the process with a warm engine and go for it.
