Author Topic: rescuing an old friend  (Read 114844 times)
« Reply #330 on: July 25, 2013, 12:43:13 AM »
Still had a lopping idle st cold start.  Smart people at work say its because of cam.  Trailer all set.
« Reply #331 on: July 25, 2013, 07:32:32 AM »
thats what ive been fighting with since day one...
just for the record.. it was NOT the cam I requested..
the machine shop built race motors... its kinda all he knew..
Jeep is going to SVE this fall/winter for motor work...
Cam, new unshaved head from eagle (thanks Mike)
« Reply #332 on: July 25, 2013, 08:26:48 AM »
also let it go on the record... I can’t thank you enough for all the time effort and energy you put into troubleshooting this...
I really couldn’t never have done it..
« Reply #333 on: July 25, 2013, 09:55:46 AM »
well, its not really the cams fault its the incorrect fuel map that the iacv is fighting before closed loop.  too much air for the fuel being put in off a dumb table
« Reply #334 on: July 25, 2013, 09:57:19 AM »
trailer has been mad maxed with light guards, new LEDs, and trailer jack!
after it close loops she crawls pretty sweet in 4 low now at 600rpm!
« Reply #335 on: July 25, 2013, 10:09:51 AM »
I always fought that rough idle before it warmed up...
I don’t think I was able to maintain a good low idle...
this will greatly help when I swap the cam out with a better lower torque curve.
the guy in there now is way too high.. that’s why it rips so well on the road.
« Reply #336 on: July 25, 2013, 10:34:18 AM »
I need a mad max trailer when backing up hill in carter st. warehouse... always seem to miss judge the opening..
winching orphaned jeeps out of fields has also taken its toll on the poor lights...
« Reply #337 on: July 26, 2013, 02:19:37 PM »
M4 work is Sucken Fick....
you even sweept the shop for me...
« Reply #338 on: July 26, 2013, 02:44:07 PM »
Smike wont brag so I will...
Trailer needed some work..
I hate the landing jacks that fold and always break...
the lights have also had a few run ins with the warehouse door and my passenger tire...
problem solved..
« Reply #339 on: July 26, 2013, 02:44:37 PM »
front cage tie in...
« Reply #340 on: July 26, 2013, 02:45:14 PM »
Some pics of the skid in place..
« Reply #341 on: July 26, 2013, 03:12:20 PM »
I like those light guards a lot. nice skid too.
« Reply #342 on: July 26, 2013, 03:28:37 PM »
any chance brake wire was touched?
got en error code from the brake control...
have to check monday or this weekend...
« Reply #343 on: July 26, 2013, 03:32:12 PM »
hmmm, i only checked the lights worked on my ZJ which doesnt have a brake controller.  i dont think i was near the brake wiring at all and wouldn't imagine the wires are anywhere near where i was welding- let me know what you find.
« Reply #344 on: July 26, 2013, 03:46:28 PM »
i was just going to run a piece of 1.25 tube from the fender to the frame, but after Matt broke the band saw blade and Arie confirmed backing up and driving over were both failure modes- out came iron work with bar.
The skid turned out pretty good.  should be pretty bom proof.  i would suggest if you ever need to pull, only pull the skid, or only pull the cross member.  installing both at once takes a trans jack and some HD wiggling.
Cage tie in should stiffen up the tub mounts where OE mounts were getting nuked, but the rubber pad should kill any vibes / rattels.
All else looks in good working order on the jeep, everything else pretty tight and lubed good.
