Author Topic: 79 Cj7 1-ton  (Read 10598 times)
gslarue
  • Jr. Member
Re: 79 Cj7 1-ton
« Reply #15 on: June 24, 2013, 11:18:33 AM »
 ;)correct , future up grads always possible
Re: 79 Cj7 1-ton
« Reply #16 on: June 24, 2013, 11:39:04 AM »
Are you leaving the leafs or going links?
I would measure how far apart the leafs are and make sure the front driver's side leaf isn't going to want to sit in the middle of the pumpkin. Spencer's axle won't fix that either.
79 Cj7 1-ton
« Reply #17 on: June 24, 2013, 11:43:47 AM »
No leaf perch in the diff. Pretty much obligated to links.
Re: 79 Cj7 1-ton
« Reply #18 on: June 24, 2013, 11:58:29 AM »
mine has perches at 36.5"
Re: 79 Cj7 1-ton
« Reply #19 on: June 24, 2013, 12:30:10 PM »
outboarding springs is not uncommon, and fairly easy.  did it on my 8 with tons and leafs  1 tons under a 7 frame deserve some steal anyway for frame contacts....
hmm i guess if there is no perch from a coil truck that might be annoying, but possible.
gslarue
  • Jr. Member
Re: 79 Cj7 1-ton
« Reply #20 on: June 24, 2013, 03:06:17 PM »
Possible 4 link front and rear. Since I have time
Re: 79 Cj7 1-ton
« Reply #21 on: June 24, 2013, 03:26:06 PM »
i think you could sell the dodge and buy my d60 and be even...
just saying.
gslarue
  • Jr. Member
Re: 79 Cj7 1-ton
« Reply #22 on: June 29, 2013, 07:00:49 AM »
So their seems to be no adapter for th400 to a ford married np 205 case. other option is np 231 or np 241 if i could find one or can i flip a dana 300. thoughts
Re: 79 Cj7 1-ton
« Reply #23 on: June 29, 2013, 07:17:57 AM »
D300 and a GM D60.  Spring perches correct width and everything.
gslarue
  • Jr. Member
Re: 79 Cj7 1-ton
« Reply #24 on: June 30, 2013, 07:38:43 AM »
gslarue
  • Jr. Member
Re: 79 Cj7 1-ton
« Reply #25 on: August 14, 2013, 06:49:27 AM »
Spring perches ordered for the rear, 4 link in the near future springs for now
gslarue
  • Jr. Member
Re: 79 Cj7 1-ton
« Reply #26 on: August 26, 2013, 12:21:42 PM »
Rear is in
[attachment deleted by admin]
Re: 79 Cj7 1-ton
« Reply #27 on: August 26, 2013, 12:41:17 PM »
your ubolts are upside down!!
Re: 79 Cj7 1-ton
« Reply #28 on: August 26, 2013, 12:54:34 PM »
this is going to be a sweet machine
