Author Topic: 04' 4300  (Read 62145 times)
Re: 04' 4300
« Reply #195 on: June 13, 2014, 02:13:24 PM »
trailer power for running, left bright, and right bright are new fed through a 40 amp auto reset breaker, and 40 amp relays.
gave me fits, one of the relay socket pigtails i got from summit two of the wires were swapped in different pin locations!
once i got that figured out, everything i did worked the first time!
Re: 04' 4300
« Reply #196 on: June 18, 2014, 11:27:33 AM »
lights worked great.
crazy rain we drove though
washed off the load :)
Re: 04' 4300
« Reply #197 on: June 28, 2014, 05:40:26 PM »
Took pinion brake apart, cleaned and adjusted.  Drum and shoes fine.  Pull handel cable snaps lol.
Fix cable with yj scrap parts.
Re: 04' 4300
« Reply #198 on: June 30, 2014, 03:49:54 PM »
regional says 1400$ to put king pins in this thing
http://www.rockauto.com/catalog/moreinfo.php?pk=200969&cc=3296875
80$ in parts? hmmmm
drives fine and straight as can be- guy i bought it from said they were just done 20K ago
 :o
Re: 04' 4300
« Reply #199 on: June 30, 2014, 04:24:57 PM »
hoping jareds shop can put a sticker on it, possibly offer some wisdom if they are actually bad or not.
Re: 04' 4300
« Reply #200 on: June 30, 2014, 04:34:10 PM »
It's like your Tercel needing ball joints and muffler bearings to get a sticker!  ???
Re: 04' 4300
« Reply #201 on: June 30, 2014, 04:39:57 PM »
not much info on web.  guess its time to buy a new impact and 1" air line  grrrr
Re: 04' 4300
« Reply #202 on: June 30, 2014, 09:11:08 PM »
Easiest test is lift a side- install tire bar in wheel hand hole and yank. You'll know. Open til 5 or 7-12 on Saturday. Let me know if any time works for you.
Re: 04' 4300
« Reply #203 on: July 01, 2014, 12:39:47 AM »
ya i did so, its got a little click on the driver side that i checked, and i see someone has pryed away and torn the lower metal seal cage so the bearing is exposed   >:(
Re: 04' 4300
« Reply #204 on: July 01, 2014, 07:34:18 AM »
There is a guy in Williamson steves truck repair.  I bring my dump truck to him to do any work on it since I just look at the lug nuts and my back starts hurting.  He did my inspection and is a straight guy
Re: 04' 4300
« Reply #205 on: July 01, 2014, 09:22:18 AM »
175$ in parts and in stock at regional- about same cost at rock auto.
Ill probably lube everything and ride dirty this weekend- asses options next week when i have time time.  Ill probably tackle it.  i watched a youtube video on doing a big truck and it didnt look too bad just heavy
Re: 04' 4300
« Reply #206 on: July 11, 2014, 01:35:07 PM »
bought parts- got home opened the hood and pulled a hub cap.  decided the parts were wrong.
went back to regional, different guy at the counter.  handed him again the registration to pull the vin, he comes out with another box and asks for 40$ more.  haha
drank 3 beers and decided my impact gun still didnt budge a lug nut, pumped a tube a grease into the truck and called it good!
bah
Re: 04' 4300
« Reply #207 on: July 11, 2014, 02:17:22 PM »
Yeah, pretty much a mandatory to have 1" impact gun for MDT and up equipment. I worked at a HD repair shop and they had HF's earthquaker 1" impact gun and it work wonders.
alternatively, get a torque multiplier? http://www.pirate4x4.com/forum/tow-rigs-trailers/1726730-anybody-use-torque-multiplier-remove-truck-lug-nuts.html
Re: 04' 4300
« Reply #208 on: July 11, 2014, 02:19:20 PM »
Alex helped me do the rear lug nuts.  it was terrible whip lash with a 5' bar on a 1" ratchet.  it was quite pain full in anyway we got them to budge.
I thought about getting another impact, i guess its inevitable i need one. bah
Re: 04' 4300
« Reply #209 on: July 21, 2014, 10:02:58 AM »
lost my battery tray cover on the way home bah!
must have left it loose when i unhooked inverter
