Author Topic: 04' 4300  (Read 62145 times)
04' 4300
« on: May 15, 2013, 10:49:02 PM »
fun truck!
home.
looks to have AC and heated mirrors, air ride seat.  juice brakes.
goose and brake controller setup, winch hookups to truck battery.
pretty clean truck.  not gona pull like a tuned cummins but it will get it done.
Re: 04' 4300
« Reply #1 on: May 15, 2013, 10:54:58 PM »
25K rear axle rating
11k front axle rating
started life as a 24' box truck
guy has two of them, its twin is at 560K
had recient king pins and service, drives and tracks straight, not a drop of oil i have found.  looks like a small weepage leak on some sort of low pressure return line.  Also an issue around the passenger front brake has some fluid on the tire.
tires are 22.5's rated for 6300lbs or so
cable e pinion brake.
50 gallon tank
fun to drive.
Re: 04' 4300
« Reply #2 on: May 15, 2013, 11:15:12 PM »
titled as a 2004 iter Van at 9820lbs
ID card in email from progress, ill see if i can get some plates on it tomorrow!
Re: 04' 4300
« Reply #3 on: May 16, 2013, 07:30:11 AM »
Beware the arm rest.....this little plastic thing is capable of removing arm hair like a damn waxing salon!
Re: 04' 4300
« Reply #4 on: May 16, 2013, 08:04:07 AM »
if you need aftermarket or factory parts LMK.
Re: 04' 4300
« Reply #5 on: May 16, 2013, 08:28:11 AM »
Should be fun, cant wait to see it with the trailer hooked up.
Re: 04' 4300
« Reply #6 on: May 16, 2013, 08:29:41 AM »
gona research gages and tuners and such.  im pretty sure tuners are a no no on this rigs, but a gage setup would be nice for boose and EGT ect
Re: 04' 4300
« Reply #7 on: May 16, 2013, 08:44:40 AM »
tuners absolutly... but might have to be dealer done..
Re: 04' 4300
« Reply #8 on: May 16, 2013, 08:48:59 AM »
They can be turned up, no doubt about it.
Bully Dog advertises such things; if it's not already there CAT could load a different program and bring it to its highest factory power level.
It's oil bath front hubs I'm sure, it's probably an inner hub seal that's oiling the wheel.
Re: 04' 4300
« Reply #9 on: May 16, 2013, 09:07:07 AM »
o i know they can be turned up, but not sure how the trans will like it.
thing shifts up and down like a machine
Re: 04' 4300
« Reply #10 on: May 16, 2013, 09:20:09 AM »
Granny-shifting, not double-clutching like you should. You're lucky that 100-shot of NOS didn't blow the welds on the intake.
Sorry it just came to me lol
Re: 04' 4300
« Reply #11 on: May 16, 2013, 09:26:03 AM »
It's fast AND furious? Lol
Re: 04' 4300
« Reply #12 on: May 16, 2013, 11:50:20 AM »
A freebie mod is to up the fuel pressure. Pull the doghouse in the cab, then pull the fitting on back of the head. Inside there's either a square drive(use a small EZ out) or some odd shape like a torx. Tighten it all the way in, then back off a half turn. Still within factory spec, but at the higher end. Should get you about 70-75 pounds. It'll help the responseiveness a wee bit. Even more if you do injectors
Re: 04' 4300
« Reply #13 on: May 16, 2013, 11:51:02 AM »
Start with asking a dealer for a reflash(re-rate) on the computer.
Re: 04' 4300
« Reply #14 on: May 16, 2013, 02:08:52 PM »
strike one at the DMV
FYI dealers should know they cant set to a private buyer with out running though there business.  Lady was nice, but 2 hours wasted and i need to go back to his dealer ship, FML
realized i have no receipt for 3000$ cash given towards "trailer"
