Author Topic: lowboy  (Read 128760 times)
Re: lowboy
« Reply #75 on: December 03, 2014, 10:23:55 AM »
my 4 spare tires, then yours and matts to make 2 steps under my car, probably dont even need any ramps
 ______
|           |O
            |O O
                                               O O
Re: lowboy
« Reply #76 on: December 03, 2014, 10:33:09 AM »
still leaves 2500lbs in rear truck axle weight rating for cargo
Re: lowboy
« Reply #77 on: December 03, 2014, 10:54:53 AM »
That doesn't seem too bad at all. Predicting within a couple hundo sounds damn accurate, good work on the modeling!
Re: lowboy
« Reply #78 on: December 03, 2014, 11:49:35 AM »
last unknown would be if we need to cut your neck support tube and move it down a foot or not.
decided to run real numbers today after i realized my car wont move again for about a month on its own....
Re: lowboy
« Reply #79 on: December 03, 2014, 11:58:48 AM »
probably 400lbs of fuel can be left out till CA also on the trailer
Re: lowboy
« Reply #80 on: December 03, 2014, 12:02:50 PM »
yup.
trailer spares will be a good idea too. I think I have one broken belt that should get swapped out, odd wear on inboard shoulder on one. Has been that way for a long time.
I think I have 2-3 loose 225s; no spare SRW 19.5s. Not sure I have any good-enough E/F 8 lug 16s, they may have gone with the wedge.
Re: lowboy
« Reply #81 on: December 03, 2014, 12:54:31 PM »
probably steal one or two F's from Matts collection if needed
loose 225s are probably good.  maybe we can come up with a CO2 tank to bring.
Re: lowboy
« Reply #82 on: December 03, 2014, 12:56:29 PM »
N2 for shocks is fine for tires, not sure on capacity though? I know CO2 lasts a hell of a lot longer but would N2 be dead after seating and filling a couple tires and then have nothing left for shocks?
Re: lowboy
« Reply #83 on: December 03, 2014, 01:07:39 PM »
ya thats what i was thinking, i have 3N tanks, but they are big and heavy
Re: lowboy
« Reply #84 on: December 03, 2014, 04:01:55 PM »
i think Tom has a Co2 tank maybe we can borrow
Re: lowboy
« Reply #85 on: December 03, 2014, 05:06:21 PM »
I'll throw you a tank and reg.
Re: lowboy
« Reply #86 on: December 03, 2014, 05:10:36 PM »
even if its just a tank i think i have a few low pressure regs
Re: lowboy
« Reply #87 on: December 03, 2014, 06:11:17 PM »
i already have it set with a hose your good to go
lowboy
« Reply #88 on: April 30, 2015, 06:20:08 PM »
Dexter pump doesn’t kick on at as low a voltage. Also never lets off when on breakaway, just holds at highest pressure.
Rolling w 3 calipers this weekend. Fix that and bleed it all next week.
Re: lowboy
« Reply #89 on: May 27, 2015, 09:59:10 AM »
your hubs 4.75" pilots?
