Author Topic: TurnedUp  (Read 106429 times)
Re: TurnedUp
« Reply #255 on: July 09, 2013, 04:36:35 PM »
Towing for 2hrs or so. Normal temps, 160-170. Glance at oil pressure gauge and it is only halfway up. Typically cruises at 40 or slightly less.
Hop out, little low on oil. Top off, good to go.
Top off when leaving Rausch, not very low.
2hrs or so in, same thing. This time I pay attention and load/RPMs seem to decrease pressure. Coming to a stop bumps it back to 40.
Check level, not low at all. Top off a little anyway and good to go again.
25min from home, does it again. Still doesn't seem low. Fucked off, I dump some in since it remedied it before. Fine again.
Get home, driver's side of block is glazed with oil and pumpkin is dripping probably every 5 seconds. Probably left a 4"x4" puddle saturated on cardboard along with lots of other little dribbles.
Random Googling of forums says these pressure sensors can kinda suck sometimes.
I spend some time with my sweet free HF light I stole from Chad and find the oil pressure sender has fresh looking oil around it. Think this could be great. Wipe it off clean and surrounding areas. Start up and there is a run coming down about 1" to the left of the pressure sensor. 99% sure it's the tappet cover.
$20 for mech gauge, $20 for pressure sensor. Going to plumb the gauge into that port and see what she says. People report wildy different readings from stock gauge and mechanical gauge. Kinda like stock is more like an idiot light than a true reading.
« Last Edit: July 09, 2013, 04:42:47 PM by Harrison »
Re: TurnedUp
« Reply #256 on: July 11, 2013, 09:13:42 AM »
Mech gauge says 70psi cold idle, 80psi cruising cold. Cluster says a hair over 40.
Mech gauge says 20psi idle hot, 60psi cruising hot. Cluster says a hair under 40.
Not sure what caused the weirdness last weekend, but I'm going to keep driving it around and if it doesn't resurface, I'm forgetting it happened.
Re: TurnedUp
« Reply #257 on: July 11, 2013, 11:21:37 AM »
Definitely a glorified idiot light, then. A lot of OE temp gauges are the same way.
Re: TurnedUp
« Reply #258 on: July 22, 2013, 10:15:23 AM »
300+ miles and no weirdness from either gauge. I'm forgetting it happened.
Re: TurnedUp
« Reply #259 on: July 22, 2013, 10:37:43 AM »
Fixed!
Re: TurnedUp
« Reply #260 on: July 22, 2013, 11:15:22 AM »
If only the puddles underneath were as easy to "fix" in the same way
Re: TurnedUp
« Reply #261 on: July 29, 2013, 11:42:48 AM »
No oil pressure weirdness at all this weekend.
4" exhaust getting ordered this week, stock rotted in half.
Nothing like rowing gears in a loaded up 12v! Sometimes I wish I had more than 5 of them...  :-X
Re: TurnedUp
« Reply #262 on: August 13, 2013, 12:10:09 PM »
New Napa trackbar sucks. It was the cheap one, but still. The bushing squishes 1/4" and ball joint has play when sawing the wheel.
Moog ProblemSolver with larger ball joint is $63 shipped from Rockauto, closeout pricing. Would be nice to unbolt, then bolt on.
Or this looks cool and gets rave reviews for a little under $100 with a poly bushing as well:
http://www.lukeslink.com/Installations.html
Would be sweet to have a "premanent fix" that I could keep adding preload to the joint.
Thoughts?
Don't feel like spending the time or money on going 3rd gen double shear.
Re: TurnedUp
« Reply #263 on: August 13, 2013, 04:24:52 PM »
lukes link only works to replace the stock joint not in a NAPA bar if I'm remembering right.
Re: TurnedUp
« Reply #264 on: August 13, 2013, 04:26:54 PM »
Napa is ok, Moog problem solver is a no-go. Problem solver ball joint is easily twice the size of the napa/stock ball joint.
Re: TurnedUp
« Reply #265 on: August 13, 2013, 05:31:30 PM »
Cut off the ball joint end and either get a bushing end on or heim and weld on bracket on the frame!
I used Luke's link and didn't last long at all.
Re: TurnedUp
« Reply #266 on: August 15, 2013, 10:16:23 AM »
I'm going to hope that's because you use yours in sand dunes. Hoping Luke's will do for the duty mine sees. If not, I will cave and build something I guess.
Another question for Brett: I am getting considerably more smoke, residue in my tailpipe, and feels slightly down on power. Thinking the 15w-40 batch I made last time really needed some gas added to thin it out. Lesson learned, but I'd like to clean things out. What do you normally do in this situation? Chad said he ran his down to nothing then added 10gal #2 and 125gal worth of Stanedyne fuel treatment. Got it hot, let it sit, ran worlds better the next day. I was thinking of grabbing some Power Service and doing the same since I'm not sure where to buy Stanedyne locally. Unless you have a better suggestion on product or procedure...
Hit 4k miles running WMO blend on the way to work today.
« Last Edit: August 15, 2013, 10:19:37 AM by Harrison »
Re: TurnedUp
« Reply #267 on: August 15, 2013, 10:21:03 AM »
That statadyne is awesome!!! I was never a believer in stuff like that and when the diplomat started running like complete shit not being able to go 55 mph or anything I was about to buy new injectors and Chad said run the statdyne. I figured what the hell and put half a bottle in with about 12 gallons and once that tank was through the car was back to normal running. I am a huge believer in that stuff now
Re: TurnedUp
« Reply #268 on: August 15, 2013, 10:53:33 AM »
Found a place that sells it locally. I think I will do the same thing Chad did and see what happens. Sounds promising
Re: TurnedUp
« Reply #269 on: August 15, 2013, 10:57:15 AM »
where and how much?
